Home
Global Communities
Services & Learning
Networks
Esri Events
ArcGIS Topics
User Groups
Events
ArcGIS Ideas
Community Resources
Community Help
MVP Program
Discussions
Help
Thuis
Producten
ArcGIS Pro
ArcGIS Pro Ideas
Sort domain names in 'Add coded value to domain tool'
CarstenSchuermann
Existing domains should be sorted alphabetically when using the 'Add coded value to domain tool'. Currently the order of existing domains is chaotic, so that it is difficult to find the desired domain if there is already a large number of existing domains.
Vind meer berichten getagd met
Status: Openen
Reacties
DamonPettitt
Having the OPTION to sort alphabetically would be nice, but there are some use cases where you wouldn't want the sort to be mandatory.
MartinaHörauf
Yes please, integrate manually sorting the values of a domain. Not alphabetically, but manually. When editing, we would like to have the mostly used valus on top of the drop down list. The only way to achieve this is to manually sort the domain and put the most important values on top of the list. Thanks a lot!
Martina Hörauf
Doe mee aan het gesprek
Meld je aan om te posten, content te volgen en meer. Nieuw hier? Registreer gratis.
Inloggen
Registreren
Snelle Links
Alle Gemeenschappen
Recente Berichten
Gebruikersgroepen
Gevolgde Content
Community Hulp
