Hi @GeraldineMoore2 ,
ArcGIS Desktop retired March 1, 2026 so we won’t be considering this idea. We recommend that you migrate to ArcGIS Pro, our fully supported desktop GIS application.
What you're describing in this Idea is already possible in ArcGIS Pro. The behavior for accomplishing this in ArcGIS Pro is documented in the "Search the project" help topic: https://pro.arcgis.com/en/pro-app/latest/help/projects/search-online-and-project-items.htm#ESRI_SECTION1_3A49AEA2B94B4133B4892D7308693FB7 . The fields that can be used to search are listed in the help topic. Credits is one of the fields that can be searched.
When searching portal items you can also search based on the content in some fields that are associated with item metadata as described in the "Search the active portal" help topic: https://pro.arcgis.com/en/pro-app/latest/help/projects/search-portal-items.htm#ESRI_SECTION1_E0F50FE2FD1143D0A5133377E584E804 . The specific fields that are available to be searched are documented here for ArcGIS Online as an advanced search capability: https://doc.arcgis.com/en/arcgis-online/reference/advanced-search.htm
Thank you for taking the time to share your ideas. We truly appreciate your contributions to continuously improving the software to help you do your work and look forward to what ideas you have for ArcGIS Pro.
Meld je aan om te posten, content te volgen en meer. Nieuw hier? Registreer gratis.
