Thank you for posting the idea. One thought I had was if you replaced the data source through python could you then recreate the join as well using the Add Join tool? This might help automate the process of changing data sources and recreating the join.
I see this is a bit old. Is there a newer thread related to this topic?
I am trying to find a find a simple method to update a feature class created from a joined table. The table will updated periodically, and I want to capture that without creating a new feature class every time. Ultimately, it will be used to create a hosted feature class used in dashboards, web apps, etc. Are there any standard workflows for this?
I am using Pro 2.9.1 and this is still not possible the change a feature class dataSource without removing the joins before.
@MaximeDemers Joins and relates are fundamental to databases and GIS. It's so frustrating that we can't update these file paths in ArcGIS Pro (I'm using 3.3 and can't figure out a way to do it)
Meld je aan om te posten, content te volgen en meer. Nieuw hier? Registreer gratis.
