Home
Global Communities
Services & Learning
Networks
Esri Events
ArcGIS Topics
User Groups
Events
ArcGIS Ideas
Community Resources
Community Help
MVP Program
Discussions
Help
Thuis
Producten
ArcGIS Pro
ArcGIS Pro Ideas
Improve stability and performance of the IN_MEMORY workspace
Hornbydd
Since it was added to ArcGIS I use the IN_MEMORY workspace regularly in my day to day work. It's great for making temporary datasets which you want to have a quick look at and not worry about deleting later. A good example is the
Spatial Join
tool which always creates a new output dataset.
But I find it to be a very unstable environment; several times in the past ArcGIS has crashed spectacularly corrupting my Geodatabase. I can replicate the problem and it's always to do with the in_memory datasets.
Whilst I appreciate it cannot support advance features (e.g. geometric networks) I often want to join the in_memory table to a featureclass. When you try to join data ArcGIS always suggests adding an index which significantly improves performance but it appears an in_memory table cannot support an index so any joins and subsequent field calculations are
painfully slow
. It would be good to see future versions of ArcGIS supporting attribute indexing on In_Memory datasets.
Vind meer berichten getagd met
Status: Openen
Reacties
There are no comments yet
Doe mee aan het gesprek
Meld je aan om te posten, content te volgen en meer. Nieuw hier? Registreer gratis.
Inloggen
Registreren
Snelle Links
Alle Gemeenschappen
Recente Berichten
Gebruikersgroepen
Gevolgde Content
Community Hulp
