Home
Global Communities
Services & Learning
Networks
Esri Events
ArcGIS Topics
User Groups
Events
ArcGIS Ideas
Community Resources
Community Help
MVP Program
Discussions
Help
Thuis
Producten
ArcGIS Online
AGOL pop-up issue's
AdenRidder
1. title bar position changes when browsing next feature
When the pop-up contains attributes from multiple features the map (eg when layers overlap) a small arrow appears in the title bar of the pop-up. If these features have a different amount of attributes the title bar moves and the mouse has to be repositioned to use the arrow for the next feature.
--> preferred: keep title bar on same position when browsing multiple pop-up features for faster browsing features.
2. pop-up moves out of view
With the pop-up opened the map can be enlarged. The pop-up disappears (partly or fully) out of the screen
--> preferred: keep pop-up always in the view
3. pop-up cannot be moved
--> preferred: move popup with relation to selected feature with a line/arrow pointing to that feature. This will also prevent the pop-up pointing to the wrong feature.
4. zoom map to selected object
When the pop-up contains attributes from multiple features the map stays at the same location when browsing each pop-up. This is confusing when the map is enlarged between showing the attributes of each feature.
--> preferred: zoom tot the location of the feature when that feature is out of view
Vind meer berichten getagd met
Status: Openen
Reacties
There are no comments yet
Doe mee aan het gesprek
Meld je aan om te posten, content te volgen en meer. Nieuw hier? Registreer gratis.
Inloggen
Registreren
Snelle Links
Alle Gemeenschappen
Recente Berichten
Gebruikersgroepen
Gevolgde Content
Community Hulp
