ArcGIS Online is a global mapping service but does not offer dynamically updated shape lengths of lines. For this project we have sewer lines between manholes and when I publish the map from ArcMap to ArcGIS Online the units (even if I have changed the WGS1984 coordinate system to show units in feet in ArcMap) will show in meters on ArcGIS Online. You can create a new field and input a formula to convert but this field does not update real time and has to be done manually. If this is truly a global service then the user should have the ability to use units other than meters.
