When using unique values when symbolizing layers all other values should be turned of by default. If I for some reason want all other values to be visible I should manually turn them on.
Every time you change the symbology of a feature class to "Unique Values", it automatically adds a symbol class for <all other values>. I think this is unnecessary and a waste of time to constantly remove it. If you have good data and are symbolizing using a field with no null values, it just adds an extra step to remove it everytime. Even if you didn't still seems like the default should be to add <all other values>, not remove them. A simple solution would just be to add this to the ArcPro options.
This is a great idea! When you click add all values, other values should be turned off because -- there aren't any. If this a user issue that people add values and don't know they are there, perhaps the add all values button should be exposed on the unique values pane as a checkbox, instead of hidden two clicks in, and checked off when you hit the unique values button.
Meld je aan om te posten, content te volgen en meer. Nieuw hier? Registreer gratis.
