Home
Global Communities
Services & Learning
Networks
Esri Events
ArcGIS Topics
User Groups
Events
ArcGIS Ideas
Community Resources
Community Help
MVP Program
Discussions
Help
Hoofdpagina
Producten
ArcGIS Online
Disable Geometry Update in Default Viewer
PaulStephenson
ArcGIS Online: There may be cases where you would like to grant a User level role the ability to edit attributes but you would like to grant an Editor or Curator (or similar) role the ability to edit geometry of features.
From the layer properties you can set the editing permissions, but it applies to
all
users.
From the default viewer/map you can turn on/off editing, but that pertains to
all
editing types.
You can set user privileges so that they can "Add layer to new map with full editing control" even when geometry edits are not allowed, but this override is a one-time deal: You cannot save the map and retain the the editing rights.
Web AppBuilder
does
have this control within the Edit widget which is fantastic; however if you want to edit the same data on Collector for instance, those editing options are not available.
There are simply times when you would want different web maps using the same data to have different editing capabilities based on the user.
I would suggest that these editing capabilities are set at either the map level (within the web map properties), or at the layer level within the web map itself, or even within the definitions of roles.
Paul
Vind meer berichten getagd met
Status: Openen
Reacties
There are no comments yet
Doe mee aan het gesprek
Meld je aan om te posten, content te volgen en meer. Nieuw hier? Registreer gratis.
Inloggen
Registreren
Snelle Links
Alle Gemeenschappen
Recente Berichten
Gebruikersgroepen
Gevolgde Content
Community Hulp
