Similar button to Import... on the Symbology tab of the Layer Properties in ArcMap, but directly applicable in AGOL
I just came to the ideas forum to post something like this! Would be great to import a layer file to set symbology etc, and would save so much time when creating view layers.
Yes please.
Yes. We would like this functionality as well.
The official answer is "no" https://support.esri.com/en/technical-article/000012452 That is a significant barrier to hosting data on AGOL. Which is costing Esri lost revenue (opportunity cost)
There is a way apparently: https://community.esri.com/groups/arcgis-python-api/blog/2019/04/09/updating-layer-symbology-with-the-arcgis-api-for-python
Just needs a button on an Item page to do this script, above.
Uniform symbology would also help: https://community.esri.com/ideas/16228-have-the-same-symbology-across-arcgis-pro-arcmap-portal-for-arcgis-and-arcgis-online
I don't see how the "way" does what the original requestor asked for--importing symbology (not just updating it). Did I miss something?
Stunning omission from AGOL functionality IMO. Iterating and updating layers in longer term projects is made sooooo much more tedious by needing to apply customized symbols manually every time a layer in a web map is replaced with an updated version.
I also second this functionality. It's a bit backwards to be able to edit hosted features directly in Pro, but not have the ability to change its symbology.
Agree with all of the above. If I'm making a map in Arc Online, it's because I wanted to make a map in Arc Online - not because I wanted to go back and forth between Online and Pro. Stunning omission indeed.
Yes Please.I primarily work in cross-organizational collaboration, and when receiving data from a collaborator to host It would be BEST if I could leverage the data owner's preferred symbology.
I support the request of the OP, if its possible to program in AGOL.
Use Case: Pulling hosted features off AGOL for modification of domains / subtypes / fields etc.. in ArcPro then rehosting as a new HFL.
Desired workflow: existing HFL in AGOL could be used to symbolize the newly hosted / updated HFL in AGOL. Ideally this option would be on the visualization tab and also available in the new Map Viewer.
This would be a useful feature, I support it.
This would be extremely useful - please add to the road map!
This would be great, as some times we publish hosted feature layers, share with a group, then they somehow lose their symbology and revert to black polygons with a black fill.
Yes please, a button on the setting page would be great for uploading lyr or lyrx
Yes please to this featureThe capability to do so is available through the backend of the Feature Layer (https://support.esri.com/en-us/knowledge-base/how-to-copy-symbology-and-apply-to-it-another-feature-l-000027205) so presumably this could be done by a UI in Map Viewer, surely?
Came on to look for an answer to this and there still isn't one 4 years later. This would be extremely helpful I now have to manually symbolize or overwrite 50 layers.
More bog standard basic functionality missing from ESRI software.
This would be super helpful!
Yes please on this functionality in AGOL.
Meld je aan om te posten, content te volgen en meer. Nieuw hier? Registreer gratis.
