Hi Scott Prindle,
This must have been a recent addition to Web AppBuilder, which is great. I think the current implementation is fine, at least there is some visual indication as to why a layer isn't being displayed and that should be easy enough to explain to users.
For an example of how this feature could be made even better, though, check out the layer list in Robert Scheitlin's app: ArcGIS Web Application
You'll see there's a little scale bar added to the check box when the layer is not within its visible range, just like in ArcMap. And ArcMap also makes the check mark itself a light gray color. If you could combine all of these features, it would be even better! Thanks,
-Ryan
Hello Ryan Kelso,
Currently, the Layer List widget in Web AppBuilder does gray out the layer's name when you are not within its visible range. However, the check box for the layer is still active.
I wanted to see if this is the functionality you were looking for. Since you mention both the layer name and the check box being grayed out, this may only be partially implemented. The layer name is in fact grayed out, but the check box is still active. Please feel free to comment to help clarify your request and how it fits into your application needs.
-Scott
Meld je aan om te posten, content te volgen en meer. Nieuw hier? Registreer gratis.
