The Chinese government requires foreign companies, such as Google maps, offering mapping services in China to use the GCJ-02 coordinate system which is not compatible with standard universal coordinate systems (WGS-84).If you convert ArcGIS boundaries located within China to KML files for importing into Google maps (which some clients require) then the boundaries will be offset by up to 500m depending on the location.A way of converting/transforming from WGS-84 to GCJ-02 is required - I believe the algorithm for converting is available from Chinese government (if you are a registered mapping provider - Google must be using this when you import) but is also available on open source communities e.g. Github.References:https://en.wikipedia.org/wiki/Google_Maps#Google_Maps_in_Chinahttps://en.wikipedia.org/wiki/Restrictions_on_geographic_data_in_Chinahttps://github.com/googollee/eviltransform
Cannot find this BUG report
I can, but I'm internal. It's on hold as we were not able to find a mathematical solution easily and Esri-China was going to do some work on their end for it. I haven't heard anything for at least a year.
Melita
is there any update on this bug?
I've heard nothing from Esri-China.
Meld je aan om te posten, content te volgen en meer. Nieuw hier? Registreer gratis.
