Home
Global Communities
Services & Learning
Networks
Esri Events
ArcGIS Topics
User Groups
Events
ArcGIS Ideas
Community Resources
Community Help
MVP Program
Discussions
Help
Thuis
Producten
ArcGIS Enterprise
ArcGIS Enterprise Ideeën
Web Mercator Completely Fails to Measure
ConradStanley1
Conrad
We use the same in-house cadastral feed projected into web mercator auxillary sphere to populate our intranet map and for desktop background to aid in location and estimation. We understand that measures will be a little off, maybe up to 10%. However, it is 200% wrong and quite misleading in ArcMap desktop, which is not the case in our intranet ArcGIS for Server map. A township measures approximately 36 sq.mi in the web-based browser map but in desktop that same township measures approximately 72 sq.mi. No one's buiding a fence but still the error is astounding!! Let's get it fixed. Below is part of the response I received from ESRI.
From ESRI Tech support
Hello Conrad,
As we discussed I have logged BUG-000088279 [Geodesic Areas cannot be calculated in the Measure Tool in ArcMap, if the Data Frame is set to a Projected Coordinate System. This is a significant problem particularly using Web Mercator.]
I do have another suggestion regarding this issue also. If you post this on the Ideas forum, where other users can vote on the issue, it will raise the profile of the problem. The Ideas forum link is:
Vind meer berichten getagd met
Status: Openen
Reacties
RobertBorchert
When using the measure tool you just need to change the measurment type from Planer to Geodesic.
RobertBorchert
Conrad,
We use the same projection.
When you open the measurement tool from the drop down Choose Measurment Type select Geodesic as the measurment type.
Doe mee aan het gesprek
Meld je aan om te posten, content te volgen en meer. Nieuw hier? Registreer gratis.
Inloggen
Registreren
Snelle Links
Alle Gemeenschappen
Recente Berichten
Gebruikersgroepen
Gevolgde Content
Community Hulp
