Home
Global Communities
Services & Learning
Networks
Esri Events
ArcGIS Topics
User Groups
Events
ArcGIS Ideas
Community Resources
Community Help
MVP Program
Discussions
Help
Thuis
Producten
ArcGIS Online
AGOL Zoom to visibility scale
ChristopherThompson
Please add a Zoom to Make Visible option for layers in webmaps. This feature is available within ArcMap and seems like it would be very helpful in web maps when visibility scales are set.
Vind meer berichten getagd met
Status: Openen
Reacties
AnninaHirschi_Wyss1
You could use the "zoom to" in the layer properties, but this zooms into the center of the respective layer wich is not necessarily the same as defined Map Extent. The Map Extent and not the Layer Extent should be taken as reference to zoom in.
AnninaHirschi_Wyss1
And this option should also be available in the Layer List Widget Configuration of Web AppBuilder
Doe mee aan het gesprek
Meld je aan om te posten, content te volgen en meer. Nieuw hier? Registreer gratis.
Inloggen
Registreren
Snelle Links
Alle Gemeenschappen
Recente Berichten
Gebruikersgroepen
Gevolgde Content
Community Hulp
