Add "zoom to" to grouped or fixed values in the category selector.
Now it is not possible to zoom to your selection that you have made in the category selector. Our selector is based on grouped values.
There does seem to be a roundabout way to accomplish this. When you first setup your category selector, set it to Features instead of Grouped Values initially, then add your zoom action for the map. Once the zoom is setup and works, then go back and change the category to Grouped Values, and at least on my most recent dashboard, the zoom action sticks around.
The workaround for this doesn't work anymore. We use this often, so i hope it gets added soon.
In the June 2022 release of ArcGIS Dashboards, elements with categories based on grouped values can now target maps with pan, zoom, and flash actions.
@SandraLuken1 . I am currently making a dashboard, and have not seen this implemented yet. Have you or anyone found the action availability for grouped values??
Hi @JoseQuintana, this works fine for me. I have a Category Selector based on Grouped Values:
And in the Actions section I can now specify the map zooms to the grouped features:
It works really well and is a big improvement. Hope this helps.
Hi @SandraLuken1 , it seems that when using a zoom action from a selector with grouped values, it doesn't appear to respect the point zoom scale set in the map. I've raised this here but just wondered if this is a problem you are able to replicate?
Anthony
@AnthonyJonesRSK This is expected behavior. The point zoom scale will be applied for point features only. When there is a group of features, the aggregated extent is used.
Hi @SandraLuken1, than you for the prompt response. The problem with the current situation is if you have two points that sit on top of one another then it zooms in far too close so you end up with a blurred base map. Could it be enhanced by changing the point zoom scale to a minimum possible zoom rather than a definitive? This would mean that if you are zooming to an aggregated extent it would zoom to the best scale for those features but not beyond the minimum. Thanks
Hi @SandraLuken1 ,
I'm unable to get the zoom option when I'm trying to select a grouped value (street name), I only get the filter option, not the When selection changes box. What am I doing wrong?
@SueJohnston44 What is the data source that you are using in ArcGIS Online/Dashboards? It's the next release of ArcGIS Enterprise that will have this included.
HI @SandraLuken1 ! I am also not able to see the zoom action with a grouped value. The source layer I am using is from a feature service. Does that make it not work?
It seems like the Zoom Action does not work when the source layer is from a feature or map service. Anyone have any luck in this scenario in ArcGIS Online? @MappyIan ? @LocatusAutomation ? @Debbie_Briedwell @SandraLuken1
@KellyKnapp35 - the source layer in the Dashboard we got to work with the Zoom action on grouped values is a hosted feature layer (published from ArcGIS Pro to Online).
Thanks @MappyIan ! I need it to work for a non hosted feature service layer. Hoping this gets implemented soon!
Hi, I am using grouped values in the category selector. Do we have the option to use the zoom for this??I tried all the ways mentioned in above, but I am not able to get it to work.
Please let me know if there is a way to get it work.
Does anyone know if we are still able to incorporate zoom, pan, and flash actions to grouped values in a category selector? or if there is a current possible work-a-round?
@hannahnisonson What verison of ArcGIS Enterprise are you using now?
@psammeta I'm not using ArcGIS Enterprise, this is from using Dashboards within our organization's online geoplatform
@hannahnisonson My work around was to add a Category Selector with Defined values first > Add actions like Zoom , Flash, Fitler save the category selector. Now once the zoom is set up > go to the category selector and change the categories from Defined Values to Grouped Values .This is what I do for all our Dashboards right now until we upgrade our version.
I found this useful, as my question about Zoom on grouped values wasn't answered directly here. See 'Category Selector', second table note.
I am on Enterprise 11.1.
https://doc.arcgis.com/en/dashboards/11.4/create-and-share/configuring-actions-on-dashboard-elements.htm
Meld je aan om te posten, content te volgen en meer. Nieuw hier? Registreer gratis.
