Home
Global Communities
Services & Learning
Networks
Esri Events
ArcGIS Topics
User Groups
Events
ArcGIS Ideas
Community Resources
Community Help
MVP Program
Discussions
Help
Thuis
Producten
ArcGIS Web AppBuilder
Attribute table in Web App Builder needs to be more obvious, easier to use
JillHalchin
A lot of users never see the tiny triangle below the web map or Web App Builder map that opens the attribute table. It's just like the one in the Flex viewer, which is brighter (yellow). With Flex, you could set the table to be open on launch, but it took up so much of the screen that I hated to do that. Perhaps AGOL maps and templates could have a bigger arrow on a full-width title bar labelled something like "Tables" or, better yet, customizable.
Also, if a feature is selected and the user closes the attribute table, the selection remains and the only way to clear it is to reopen the table. A lot of users won't figure this out on their own. This might be resolved with a Clear Selection button on the table title bar, or a general Clear Selection button that works on any selections in the map or table.
Vind meer berichten getagd met
Status: Openen
Reacties
Scott_Prindle
When you configure the Attribute Table widget, you can check the
Initially expand the widget
option so it will appear 'opened' in the app.
http://doc.arcgis.com/en/web-appbuilder/create-apps/widget-attribute-table.htm
Doe mee aan het gesprek
Meld je aan om te posten, content te volgen en meer. Nieuw hier? Registreer gratis.
Inloggen
Registreren
Snelle Links
Alle Gemeenschappen
Recente Berichten
Gebruikersgroepen
Gevolgde Content
Community Hulp
