I'm using ArcMap 10.4 and when I insert my table (256 rows and 19 columns) it's only inserting maybe 60 rows. Is there a size limitation to tables? I am new to ArcMap but it just seems like there will probably be another form of workaround, or I'm doing it wrong. I went to Insert, Object, and linked it that way.
Thanks for any help
Derek
Where are you trying to insert a table?
I'm just trying to import it into layout view.
I always had better luck highlighting desired fields in Excel, copy and paste within layout. This seems to work better than Insert, Object. I just tried and copied 738 records from spreadsheet in layout
Closing this for ArcMap. If tables are being cut off in ArcGIS Pro layouts, please contact Technical Support.
Thank you.
Meld je aan om te posten, content te volgen en meer. Nieuw hier? Registreer gratis.
