Home
Global Communities
Services & Learning
Networks
Esri Events
ArcGIS Topics
User Groups
Events
ArcGIS Ideas
Community Resources
Community Help
MVP Program
Discussions
Help
Hoofdpagina
Producten
ArcGIS Online
Save Web Mapping application as a new map
AngeloMarino
While it is possible to use "save as" when you are in the map window, once you have published a web mapping application the only thing you can do with that application is recongifure it. I would like to use the "save as" feature for one of my applications so I can change one configuration feature and deploy the application. I have all the colors and text the way I want it and all I want to do is deply the map without the edit button button visibile. I don't want to have to go through all the configuraton again just to change one feature and I don't want to share the editable map to anyone outside my organization. Essentially a copy and "paste as" feature would be nice for web mapping applications.
Vind meer berichten getagd met
Closed
Status: Closed
Reacties
JamieSheehan
Totally agree.... we have a series of Apps with different content (for different regions), but want them all to look the same. If I could simply do a 'save as' I wouldn't have to create a completely new one each time and make each have the same settings.
Doe mee aan het gesprek
Meld je aan om te posten, content te volgen en meer. Nieuw hier? Registreer gratis.
Inloggen
Registreren
Snelle Links
Alle Gemeenschappen
Recente Berichten
Gebruikersgroepen
Gevolgde Content
Community Hulp
