Home
Global Communities
Services & Learning
Networks
Esri Events
ArcGIS Topics
User Groups
Events
ArcGIS Ideas
Community Resources
Community Help
MVP Program
Discussions
Help
Thuis
Producten
ArcGIS Enterprise
ArcGIS Enterprise Ideeën
Multiline Text symbols ibn ArcGIS JavaScript API
ManishkumarPatel
It would be nice to have an option for providing multiline text symbols.
var smTxt = "Line 1 text here \n Line 2 text here";
var textSymbol = new esri.symbols.TextSymbol(smTxt, font, new dojo.Color([0, 0, 0, 1]));
Results is displayed as below:
Instead should be displayed as below:
Line 1 text here
Line 2 text here
A simple idea may save lot of time for handling this kind of situtations.
Hoping this implements soon.
Best Regards,
Manish Patel
Vind meer berichten getagd met
Status: Openen
Reacties
SimonUyttendaele
See :
https://github.com/Chaussette/esri.symbol.MultiLineTextSymbol
Lets hope esri includes this in the API officially...
John_S
The Javascript how you describe it working is working correctly. \n does not mean anything except \n in javascript / html. \n is the new line character for python, so when you're calculating, scripting, labeling, etc... using python, you definitely want \n to create a new line. In javascript / html the new line is handled by the break tab <br />. If you need a new line, you should either use the break tag as you're constructing the string or if your string already has \n in it, you should run a find and replace to replace the \n with the break html tag.
Doe mee aan het gesprek
Meld je aan om te posten, content te volgen en meer. Nieuw hier? Registreer gratis.
Inloggen
Registreren
Snelle Links
Alle Gemeenschappen
Recente Berichten
Gebruikersgroepen
Gevolgde Content
Community Hulp
