We build Feature Classes by creating Attributes and adding Domains. We set the various values and the Domain needs to be compatible.
I would like to see the ability of a Domain to define the values of the attribute
Example:
You create a new Attribute. You give it a name and alias
Then you select the Domain that is desired
The Domain then sets
Data Type
Allow NULL
Number Format
Default
Precision
Length
Such that these values are made to fit the needs of the Domain.
To take it a step further.
You want to create a new Feature Class or Table
Open a dialog to create the FC or Table
Select the Domains you want included. Each time you select one it prompts you for a name and alias. Then you can also select the same Domain again if it is being used for a different attribute
