In the attributes pane when you hover over a column name a tool-tip of the field definition is displayed. This is not helpful to editors as it covers up the values. It would be nice if this feature could be toggled off.
I find it easier to edit in QGIS simply because of these unnecessary and unhelpful tooltips.
Yes, please allow folks to turn this tool tip off. It is not helpful.
I agree.
I would agree that the pop-up is very annoying and interferes with editing work flow. Please make this optional. Thank you.
As an editor, I agree with this suggestion 100%.
"Tip:Hover the mouse over the field name to see the data type, default geodatabase value, and other field properties."
I don't need this.It interferes with entering attributes, so I wish there was a setting to hide it.
This is still an issue in ArcGIS Pro v 3.3.1. It was one of the very first complaints my guys had when we started training on Pro coming from the ArcMap environment. Would be nice if this could get taken care of in an upcoming version.
I agree also that this is very annoying, it is always covering up items that I am trying to read. It also does it in the symbol gallery and attribute tables. I do not find it useful and it gets in the way all the time. If someone knows how to turn this off please let us know. Thank you
I agree this is very annoying when trying to edit attributes. It would be very nice if you could turn that feature off.
Like Sean Avery screening Martin Brodeur.
When using a docked attribute window to edit attributes on features in ArcGIS Pro, a map tip-like window appears if you leave your mouse hovered over a field name, obscuring the attributes you're trying to enter. It would be great if this option was able to be turned off in the application settings.
Thank you for the comment @ErinCovill1 I took a look and it doesn't appear that you added your kudos to the idea. While comments are important, kudos (the number of votes) that an idea receives is one of the primary pieces of data that we use to determine traction and trends as we monitor idea activity over time.
Please see https://community.esri.com/t5/custom/page/page-id/arcgis-ideas for a high level overview of how ArcGIS Ideas works. For more details, see Frequently Asked Questions about ArcGIS Ideas
Thank you for your participation in the community and for helping us prioritize future development efforts for ArcGIS Pro.
No response from esri yet? I am still seeing this behavior in Pro 2.9.2. It is very annoying.
Meld je aan om te posten, content te volgen en meer. Nieuw hier? Registreer gratis.
