Home
Global Communities
Services & Learning
Networks
Esri Events
ArcGIS Topics
User Groups
Events
ArcGIS Ideas
Community Resources
Community Help
MVP Program
Discussions
Help
Hoofdpagina
Producten
ArcGIS Pro
ArcGIS Pro Ideas
Python Value Table Improvements
RandalGreene1
At 10.1, python toolboxes were introduced and included the ability to have multi-column value table parameters. However, they lack the ability to do useful things such as drive the values in a column of type Field based on the selection in a column of type Feature Layer, or pick the values for a column of type String from a coded value domain.
I hereby vote to make the python geoprocessing tool multi-column value table parameters full fledged, as can be programmed in a dll gp tool. This should be done both in python toolboxes and in regular python tools (by adding value table, and a sub-dialog to define them, to the parameter types that can be defined via a python tool's properties).
Thanks in advance...
Meer berichten vinden met de tag
Python
Status: Openen
Reacties
There are no comments yet
Doe mee aan het gesprek
Meld je aan om te posten, content te volgen en meer. Nieuw hier? Registreer je gratis.
Aanmelden
Registreren
Snelle links
Alle communities
Alle recente berichten
Gebruikersgroepen
Gevolgde content
Hulp bij de community
