Home
Global Communities
Services & Learning
Networks
Esri Events
ArcGIS Topics
User Groups
Events
ArcGIS Ideas
Community Resources
Community Help
MVP Program
Discussions
Help
Thuis
Producten
ArcGIS Enterprise
ArcGIS Enterprise Ideeën
Add ability to document Python Toolboxes from within pyt file.
JeffJacobson
I would like to be able to add documentation to my Python Toolboxes inside of the pyt file instead of creating the documentation through ArcGIS Desktop "Item Description" process (which generates XML files).
Using the existing method, sometimes if I add a parameter to a Python Toolbox tool, the XML files will be regenerated and I have to redo all of the documentation from scratch. Not cool.
Vind meer berichten getagd met
Status: Openen
Reacties
ShaunWalbridge
Not a direct solution to this issue, but one thing that does help is adding your XML files to a version control system -- I do this with all of the documentation, and this allows you to move between versions easily. The issue of XML regeneration has been fixed, at 10.1SP1 if you add parameters, I can confirm the rest of the help is retained.
Doe mee aan het gesprek
Meld je aan om te posten, content te volgen en meer. Nieuw hier? Registreer gratis.
Inloggen
Registreren
Snelle Links
Alle Gemeenschappen
Recente Berichten
Gebruikersgroepen
Gevolgde Content
Community Hulp
