Home
Global Communities
Services & Learning
Networks
Esri Events
ArcGIS Topics
User Groups
Events
ArcGIS Ideas
Community Resources
Community Help
MVP Program
Discussions
Help
Thuis
Producten
ArcGIS Pro
ArcGIS Pro Ideas
Currupted MXD File and Missing Properties or Fields
TawanBanchuen
Hi ArcGIS users,
Like many of you, I often find that a map document that I have been working for hours become currupted. I finally got really frustrated this morning and contacted the ESRI New Zealand customer support and here is their response:
"Hello Tawan,
I have logged a call #159800 in regards to your question. Later this morning I will have a look at your document but in general map documents gets corrupted when using corrupted data or if properties of layer(s) reference wrong/missing fields or something similar. The recommend way is to recreate the map document from scratch adding data from the source and specifying all properties. Alternatively, you can add layer files if you have them but it has a certain possibility of corrupting the map if layer files reference wrong/missing fields.
Regards,
GIS Technical Consultant
Eagle Technology Group Ltd"
Surely, if this is the case, ESRI can handle the error more gracefully, for instance, in the same manner as a missing source file and open the map document anyway. Not being able a map document just becuase of a few missing fields/properties is absolutely a dissaster.
Please don't forget to vote if you agree.
Cheers guys,
Tawan
Vind meer berichten getagd met
Status: Openen
Reacties
There are no comments yet
Doe mee aan het gesprek
Meld je aan om te posten, content te volgen en meer. Nieuw hier? Registreer gratis.
Inloggen
Registreren
Snelle Links
Alle Gemeenschappen
Recente Berichten
Gebruikersgroepen
Gevolgde Content
Community Hulp
