Should be an option button in the Replication set up. Default to 3857.
If things were that simple what would they need GIS people like you for? Just saying...
Well, actually it turned out not to be that bad. The workflow did indeed work perfectly, for a viewer and two SDEs and their child GDBs. However, I imagine this is a common workflow - where GIS departments would want file GDBs in web mercator for web viewers. But they keep SDE in state plane. It would be an area for streamlining the interface.
I have been using this workflow for years now and as you said it in not a big deal.
Is there an updated KB article on this? The original link appears to be broken. Or is there an updated process for use with ArcGIS Pro? The export data to geodatabase geoprocessing tool was added to Pro earlier this year and was I wondering if that was the tool being used in the original KB article.
https://community.esri.com/t5/arcgis-ideas-blog/your-ideas-in-arcgis-pro-3-3/bc-p/1431910
Thank you,
Chris
Thanks all for your contributions to this Idea. Documentation for the extract process can be found at the link below. The new Extract Data from Geodatabase tool is an equivalency tool that matches the functionality of the tool in ArcMap and will allow access to the same workflows. Extract Data to a Different Spatial Reference
Meld je aan om te posten, content te volgen en meer. Nieuw hier? Registreer gratis.
