<local:SLTrafficCounts />
In this sample, MapTipPosition is the name of the project.You don't need to create a new project, you can just include theMapTipPositionBehavior.cs source in your project and add the behavior to your map.
using System; using System.Net; using System.Windows; using System.Windows.Controls; using System.Windows.Documents; using System.Windows.Ink; using System.Windows.Input; using System.Windows.Media; using System.Windows.Media.Animation; using System.Windows.Shapes; namespace SLTrafficCounts { public class PositionMapTip : Behavior<Map> { private Point _mousePos; // Track the position of the mouse on the Map /// Distance between the MapTip and the boundary of the map public double Margin { get; set; }
xmlns:local="clr-namespace:SLTrafficCounts" xmlns:i="clr-namespace:System.Windows.Interactivity;assembly=System.Windows.Interactivity" . . . <esri:Map x:Name="MyMap" Extent="748437,575771,1204687,267438" MouseClick="QueryPoint_MouseClick"> <i:Interaction.Behaviors> <local:SLTrafficCounts /> </i:Interaction.Behaviors>
I'm not clear as to how to resolve the missing reference for xmlns:local="clr-namespace:MapTipPosition"
This bog post is talking about positionning maptips inside maps. It may be helpful : http://blogs.esri.com/Dev/blogs/silverlightwpf/archive/2010/09/30/How-to-keep-MapTips-in-the-Map.aspx
