I would like to see more keyboard shortcuts, and maybe the ability to make your own keyboard shortcuts.
ArcGIS Pro could really use shortcuts for "Save Edits" and "Discard Edits"!
A shortcut for the "Clear" function in the Edit tab would also be very helpful.
Here are Pro shortcuts: https://www.esri.com/content/dam/esrisites/en-us/media/pdf/g526942-arcgis-pro-kybrd-shrtct-FINAL.pdf
Have you tried using keyboard accelerators to set shortcuts you're looking for?
Something that can be helpful is to click the 'Show command IDs on ScreenTips, and then when you're working in the interface and want to create a shortcut for a specific command, you can confirm that it is actually the same command that you're creating the shortcut for in the Customize options.
Meld je aan om te posten, content te volgen en meer. Nieuw hier? Registreer gratis.
