Home
Global Communities
Services & Learning
Networks
Esri Events
ArcGIS Topics
User Groups
Events
ArcGIS Ideas
Community Resources
Community Help
MVP Program
Discussions
Help
Thuis
Producten
ArcGIS Pro
ArcGIS Pro Ideas
Put Time in the Geometry Field
GeorgeNewbury
Currently Time Is placed in the attribute field, making it associated with all of the geometry of the object. In the case of a single point, this is ok, but for more complex geometry, mulitpoint, polyline, polygon, it is not. We should be integrating time into the geometry of each node. Each node should have X, Y, Z, M, B, D and where B and D represent the time of Birth and Death (Or start/end time) of that vertex.
Where would this be useful? My immediate requirement is for georeferencing video. I currently put time (or a derivative of it like a frame number) in the M column, but when the video stops at one place (vehicle stopped), then there is a problem. Since the video didn't move, it should't move spatially, only temporally. So the M value should change.. But I wouldn't want to be storing multiple points at the same location (besides in some cases it is difficult because of XYZ and M tolerance). Thus if we add the Birth and Death of the Vertices then I can have a temporally correct representation of the location of the video. We have video represented as a line, because it makes it made an efficient way for figuring out where to start the video based on a user click (reverse geocode).
If we are going to model the physical world, then we should strive to embed the fundamentals of that world in the models that we create. Time complements space, and so incorporating it at the most fundamental level would lead to additional capabilites for the analysts building the next GIS.
Vind meer berichten getagd met
Status: Openen
Reacties
DavidKnudsen
I don't use time in this way in my work, but in reading about ESRI's "integration" of time into the GDB, I've also wondered why time wasn't simply another coordinate dimension. I had assumed merely X, Y, Z, M, T (single time coordinate), with the stipulation that two space-coincident points would now be valid space-time geometry, being distinguished by their time coordinate.
On the other hand, I assume this creates some tremendous rendering and calculation issues, possibly unresolvable. If there isn't a white paper discussing the theoretical space-time data management/storage options and the choices made by ESRI, then maybe there should be...
PolatDALKIRAN
I just wonder you developers why don't you develop and sell your ideas in
GIS Extensions Market.
You have so many ideas and make others earn money instead of yourself.
Doe mee aan het gesprek
Meld je aan om te posten, content te volgen en meer. Nieuw hier? Registreer gratis.
Inloggen
Registreren
Snelle Links
Alle Gemeenschappen
Recente Berichten
Gebruikersgroepen
Gevolgde Content
Community Hulp
