In the Side Panel, provide an option to let the Dashboard user reset all of the Selectors to their default values.
As noted by @Kevin, new setting to allow dashboard reset was added as part of the November 2022 update of ArcGIS Online. All things remaining equal, it will be picked up by ArcGIS Enterprise 11.1.
Dashboard Reset button added in November 2022.
https://doc.arcgis.com/en/dashboards/latest/create-and-share/dashboard-settings.htm#ESRI_SECTION1_7CC93F351C284BEF8913A368E017CE51
At the June 2021 update to Dashboards, you can now allow users to clear their selector inputs at run time. Not a "reset all", but should help with this use case.
Kevin, great idea from 2 years ago! Any prioritization on this one ESRI?
Sorry, yes it is Operations Dashboard. Thank you!
Hi Kevin - since you wrote "Dashboard" I'm assuming this is an Operations Dashboard idea. Is that correct? I went ahead and added that as the category. Please correct if needed.
Meld je aan om te posten, content te volgen en meer. Nieuw hier? Registreer gratis.
