Home
Global Communities
Services & Learning
Networks
Esri Events
ArcGIS Topics
User Groups
Events
ArcGIS Ideas
Community Resources
Community Help
MVP Program
Discussions
Help
Thuis
Producten
ArcGIS Utility Network
Manually Specify Flow Direction for an Electric Feature
RobertBorchert
Often in Electric GIS we draw 2 or 3 phase lines as a single line. Often a singel phase will break away for a little bit and come back to the ohter 1 or 2 phases and join back up. This creates a LOOP and a variety of funcitons will not work such as setting flow direction, tracing downstream, exporting to an outage managment program.
What we need is a third Geometric Network Attribute. We have Enabled and Ancillary Role. We need something like Manual Flow direction. Perhaps something that will set flow direction for the selected line to digitized direction. The existing tool only works for Enterprise GIS and on the entire system. For it to work we would first need a tool to set digitized direction to Flow Direction. Fix the lines in quesition and then set flow to digitized direction. And we would need it to work outside of a Enterprise Network
Vind meer berichten getagd met
Status: Openen
Reacties
There are no comments yet
Doe mee aan het gesprek
Meld je aan om te posten, content te volgen en meer. Nieuw hier? Registreer gratis.
Inloggen
Registreren
Snelle Links
Alle Gemeenschappen
Recente Berichten
Gebruikersgroepen
Gevolgde Content
Community Hulp
