Add a geodatabase feature that is a simple organization tool (e.g. folders) that doesn't add any functionality to the data or impose any restrictions like the feature dataset imposes.
Great idea. Here's the deal. Almost everyone in the REAL world uses Datasets as folders. Many folks do not know the implications of this, and are not aware that was not their original intent. They were for topology, networks and other complex functionality. They lock all FCs in them. However, we still use them like folders. Almost everyone does. Because what is the alternative? There isn't one. Hundreds of layers in a flat list is unwieldy.
When I asked the Data Management team leads at a UC sometime early last decade, they said " just use a different database for a different group of layers". With dozens of 'groups' of layers, like by jurisdiction or utility category etc, that won't work, to have dozens of SDE db connections. So we soldier on, with Datasets and their Locks. Hope they can create a concept of SDE database 'folders' that merely serve to organize visually. No locking, no need to include networks and topologies. Simply visual appearance. This should be very easy to code. And I love your idea of sub-folders. Allow infininite sub-directories.
Team Esri-- thoughts??
Allow to create sub/child datasets or Group datasets in Geodatabase/FGDB
Thanks for the confirmation @Anonymous User ,One option for dataset organization is the Catalog Dataset, take a look and let us know if this is something that you find useful.Link - An Overview of Catalog Datasets
Whoah! that idea was 2010, and yet ESRI added create new Feature Dataset as the top choice in Catalog create new in ArcPRO? That is madness.
Hi @SSWoodward - indeed it is! My apologies, I did look but I guess not deep enough 🙂 Great to see there is quite an appetite for it 🙂
Thanks for the Idea, @Anonymous User. It looks like this Idea may be a duplicate of one posted on the Data Management Exchange. I've linked it below. If you think it's similar, I'll merge them so your comments and kudos are added to it.
Link to Idea - Add Ability to Store Feature Classes and other ...
Given the widespread misuse of 'feature datasets' could ESRI consider creating a new database structure equivalent to adding a subfolder in windows?
e.g. geodatabase (right click)> New > feature class OR feature folder (bucket, compartment whatever you want to call it...) OR feature dataset OR rest of the options.
NB - feature class top of list!
Being able to implement a sub-directory structure as well as a directory/folder structure to geodatabase features would further ease the organisation of layers in a geodatabase.
It seems strange that shapefiles can be organised this way but not any layers involving a DBMS like Oracle or SQL Server, even though the latter is the newer technology.
Without any adequate means of organising geodatabase features, finding a layer to add to a map can involve having to scroll through hundreds of irrelevant layers, made even more difficult from the fact that the "Add Data" dialog box cannot show very many layers at once, being so small and not resizable.
If ESRI could provide this ability, I wouldn't have this problem:https://c.na1.visual.force.com/apex/ideaView?id=087300000008G0I&returnUrl=%2Fapex%2FideaList%3Fc%3D09a300000004xET%26sort%3Drecent
We have so many layers etc. that some users have started calling SDE the "data dumpster".This is exactly how the original DOS operating system started out. There were no folders, and all files were stored in the single root directory. When users listed files, they saw every file name.Which reminds me, the original DOS also restricted file names to 8 characters. While SDE allows more than 8, it is limited to the database table limits. There is no reason "layers" etc. could not be abstract synonyms which would allow 128+ characters, including spaces!
Meld je aan om te posten, content te volgen en meer. Nieuw hier? Registreer gratis.
