Sure. I just added it as attachment to this post in case other dev will need to do something similar. Kindly see attached WPF project.
Can you try to run Fiddler with your application to monitor web requests? I really could not replicate the issue you are facing with OverviewMap. I modified a copy of this sample in WPF http://help.arcgis.com/en/webapi/silverlight/samples/start.htm#OverviewMap. . Placing OverviewMap code in another Window with the code I included in my last post.Did you replace "OtherWindow" with your own class name?If that still does not work for you, download Toolkit source code from CodePlex http://esrisilverlight.codeplex.com/ and debug through it.
public static readonly DependencyProperty MapProperty = DependencyProperty.Register("Map", typeof(Map), typeof( OtherWindow), new PropertyMetadata(OnMapPropertyChanged)); public static readonly DependencyProperty LayerProperty = DependencyProperty.Register("Layer", typeof(Layer), typeof( OtherWindow), new PropertyMetadata(OnLayerPropertyChanged));
Map and Layer property in your code use DependencyProperty that sets Map and Layer of the OverviewMap contro? (similar to code below)I do not get error when I have the following code in OtherWindow.xaml.cs public Map Map { get { return (Map)GetValue(MapProperty); } set { SetValue(MapProperty, value); } } public static readonly DependencyProperty MapProperty = DependencyProperty.Register("Map", typeof(Map), typeof(OtherWindow), new PropertyMetadata(OnMapPropertyChanged)); private static void OnMapPropertyChanged(DependencyObject d, DependencyPropertyChangedEventArgs e) { OtherWindow ow = d as OtherWindow; if (ow != null && e.NewValue is Map) ow.MyOverviewMap.Map = e.NewValue as Map; } public Layer Layer { get { return (Layer)GetValue(LayerProperty); } set { SetValue(LayerProperty, value); } } public static readonly DependencyProperty LayerProperty = DependencyProperty.Register("Layer", typeof(Layer), typeof(OtherWindow), new PropertyMetadata(OnLayerPropertyChanged)); private static void OnLayerPropertyChanged(DependencyObject d, DependencyPropertyChangedEventArgs e) { OtherWindow ow = d as OtherWindow; if (ow != null && e.NewValue is Layer) ow.MyOverviewMap.Layer = e.NewValue as Layer; } In MainWindow.xaml.cs private void Window_Loaded(object sender, RoutedEventArgs e) { OtherWindow ow = new OtherWindow() { Map = this.MyMap, Layer = new ArcGISTiledMapServiceLayer() { Url = (this.MyMap.Layers[0] as ArcGISTiledMapServiceLayer).Url } }; ow.Show();
I'm not sure I know how to replicate the issue so you have two different windows, one with your map and one with OverviewMap? How does OverviewMap set its Map property? I suspect the problem here is with <esri:OverviewMap x:Name="MyOverviewMap" Map="{Binding ElementName=MyMap}"> Element binding will not work if MyMap exists in a different window. For the window that will hold OverviewMap control, you may need to create a Map DependencyProperty for the OverviewMap control to use.
I have created a WPF Window. If I place the OverviewMap Control in the new window and load the application it freezes at the place where you set the Layer property. If I pull the overview map out of the new window and place it on the form with the map it works perfectly. Is this an known error and is there a work around?
