What is the difference between minimum match score and minimum candidate score in Geocoding?
The difference between the two lies in the geocoding process. The address you provide is broken up into multiple representations of that address. For example, "12 Concorde Place, Toronto, ON" could have the following representations:
Each representation is searched for in the address locator (or in some cases against many locators). Each search produces a list of candidates, each having a match score. This match score represents how closely the search string matched the value in the locator. These candidates are then ranked against each other according to their match score and the accuracy of the locator/representation.
Continuing with the example from above, both "12 Concorde Place, Toronto, ON" and "Toronto, ON" could generate a match score of 100 since the full address was matched to a street address and the city was matched against a point or polygon for the city. However, the street address match is clearly superior and would get a higher candidate score.
This is just one example of what could affect the match and candidate score, but it should help you wrap your head around this obscure concept.
Exactly what is implied:
In order to be considered a MATCH, the candidate will need score of 'X'
In order to be considered a CANDIDATE, the address will need a score of 'Y'
If you set your MATCH score high, and your CANDIDATE score low, you probably won't get many matches but you'll probably get a ton of candidates to consider.
Joe, thank you very much for your valuable input.
May you please elaborate more about the difference between the MATCH and the CANDIDATE?
did you check the help file link?
Yes, I checked it out but I did not get the point.
Would you please give me a practical example that can better illustrate the difference?
Thank you very much David, I got the point now
