We have been asked a few times, is there a way to validate the asset package without having to apply it to a Utility Network. Here is a simple toolbox that will do that. It is limited to the first 100 errors. We will look at exposing this limit in the future.
Here is an example output:
is there a validate asset pakage for last untools v3.1.1?
Thank you
Thank you for a tip. I had untools 2.4.1 installed. To troubleshoot further, I deleted the cloned Python environment , created new clone and installed untools again. Once Pro was re-strated, the tool worked as expected. Thank you for a prompt response.
This is what you should see in Pro 2.4.1 with untools 2.4.1
Can you check which version of untools you have?
Hello, I have downloaded the Asset Package validation toolbox Validate Asset Package, unzipped and followed Use a custom geoprocessing tool instructions to install. When double-click on the tool it opens without any parameters (cannot enter the Asset Package name to validate). I am using ArcGIS Pro 2.4.1. Am I not using the tool correctly? Please advise
Uninstalled UNTools Python Pkg > installed updated version > restart ArcGIS Pro > works now.
The update pkgs tools wasn't picking up the most recent version so needed reinstall.
Any ideas on this error message?
2019-05-29 11:05:13 Starting AssociationsValidation.main2019-05-29 11:05:13 Starting AssociationsValidation._validate_associations_have_rules2019-05-29 11:05:13 Finished AssociationsValidation._validate_associations_have_rules 0.0223424999999934932019-05-29 11:05:13 Finished AssociationsValidation.main 0.039641400000007822019-05-29 11:05:13 Creating UN data element2019-05-29 11:05:13 Reading B_AttributeIndex - None2019-05-29 11:05:14 Reading B_AttributeIndex_Fields - None2019-05-29 11:05:14 Reading _Version - None2019-05-29 11:05:14 Removing the following items from XML:{}2019-05-29 11:05:15 Finished AssetPackage._initialize 10.6834668999999992019-05-29 11:05:15 Purging describe cache: CacheInfo(hits=0, misses=0, maxsize=128, currsize=0)2019-05-29 11:05:15 Starting UtilityNetwork._initialize 2019-05-29 11:05:15 A python error occurred. 2019-05-29 11:05:15 EXCEPTIONTraceback (most recent call last): File "C:\Users\cmartin\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone2\lib\site-packages\untools\common\wrappers.py", line 83, in wrapper return func(*args, **kwargs) File "C:\Users\cmartin\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone2\lib\site-packages\untools\gptools\tools.py", line 546, in run un = UtilityNetwork.from_cache(f'{uuid.uuid4().hex}/FeatureDataset/UtilityNetwork', item=cache.as_posix()) File "C:\Users\cmartin\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone2\lib\site-packages\untools\utility_network\un.py", line 75, in from_cache return cls(utility_network=utility_network, cache=item) File "C:\Users\cmartin\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone2\lib\site-packages\untools\utility_network\un.py", line 40, in __init__ self._properties = self._initialize(kwargs.pop('cache', None)) File "C:\Users\cmartin\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone2\lib\site-packages\untools\common\wrappers.py", line 288, in wrapper result = func(*args, **kwargs) File "C:\Users\cmartin\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone2\lib\site-packages\untools\utility_network\un.py", line 47, in _initialize self._xml = read_xml(cache) File "C:\Users\cmartin\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone2\lib\site-packages\untools\utils\serializer.py", line 27, in read_xml return lxml.etree.parse(str(xml_file), parser=parser).getroot() File "src/lxml/etree.pyx", line 3426, in lxml.etree.parse File "src/lxml/parser.pxi", line 1840, in lxml.etree._parseDocument File "src/lxml/parser.pxi", line 1866, in lxml.etree._parseDocumentFromURL File "src/lxml/parser.pxi", line 1770, in lxml.etree._parseDocFromFile File "src/lxml/parser.pxi", line 1163, in lxml.etree._BaseParser._parseDocFromFile File "src/lxml/parser.pxi", line 601, in lxml.etree._ParserContext._handleParseResultDoc File "src/lxml/parser.pxi", line 711, in lxml.etree._handleParseResult File "src/lxml/parser.pxi", line 638, in lxml.etree._raiseParseErrorOSError: Error reading file 'C:/Users/cmartin/AppData/Local/ESRI/conda/envs/arcgispro-py3-clone2/lib/site-packages/untools/data_files/un.json': failed to load external entity "C:/Users/cmartin/AppData/Local/ESRI/conda/envs/arcgispro-py3-clone2/lib/site-packages/untools/data_files/un.json" Failed to execute (ValidateAP).
