Klamath Strategic Habitat Conservation brengt u...<\/P>
<\/P>
Tasseled Cap voor Landsat 8 - in een toolbox!<\/STRONG><\/P><\/P>Invoer is een map met L8-gegevens.<\/P><\/BODY><\/HTML>
thanks,Can I using landsat 8 KSHC_Landsat8_Tools.tbx.zip?
if you are still interested, you can find the solution of your problems here:
Re: How to perform Tasseled Cap Function/"Greenness" Factor in GIS?
Cheers
Hi
Thanks for sharing..
As Mario said, script may be missing because the path shows as below,
'U:\04_Programming\20_GitHub\LandSat8_TasseledCapTransform\funL8TasseledCap_tbx.py
Thanks again
Hi Daryl,
thanks for your tbx.
Unfortunately I've some problems with the installation.
1) I've just put in the C:/programs/arcgis/.../toolbox folder, and then
2) in ArcGIS -> right click on ARCtoolbox -> add toolbox.
When I run the tbx it doesn't work...
Maybe the scrips is missing...
Could you give me any suggestions?
Thank you very much
Mario
P.S. I'm using ArcGIS 10.3
