Hi everyone, I am just starting to use ArcGIS Pro, and I am trying to create a local scene.
I exported a DEM model from Agisoft Photoscan as a a GeoTiff Elevation Data. I also exported a high quality JPEG that I want to drape over the elevation data. The problem is that when I add the .tif as a elevation source it says "an elevation surface needs to contain supported elevation information and the data source needs to be accessible". The .tif displays fine as a raster, showing a black and white contrast image.
I assume it has something to do with how I export the DEM from Photoscan. I do not understand what the no-data value is, I tried it as -3.40282, I found that value on a different forum regarding ArcMap.
Any help would be appreciated, I am trying to figure things out as I go. Thank you
