Hi Guys,
I 'm trying to automate the conversion raster to polygon and the rasters files are in "TIF" format. I have the code below. However, I 'm getting an error while executing it. Could you have some suggestion please? Thank you very much for your time and help!
Regards,
Subhasis
Code:
import arcpy, os
from arcpy import env
from arcpy.sa import *
#To overwrite output
#Set environment settings
env.workspace = "C:/Subhasis/Test/Neshanic_Python/extract"
outws="C:/Subhasis/Test/Neshanic_Python/extract/clip/"
#checkout ArcGIS spatial analyst extension license
inraster = arcpy.ListRasters("*", "TIF")
for i in inraster:
filename=os.path.splitext(i)[0]
outPolygons= outws + str(filename) + '.shape'
field = "VALUE"
arcpy.RasterToPolygon_conversion(inraster, outPolygons, "NO_SIMPLIFY", field)
