We are using the Esri measurement dijit in our site. We have a map that shows 1000' buffers around certain property types. When you use the measure tool it reports an incorrect value while moving the mouse. Once the user double clicks to end the measurement the distance seems correct. Please see the attached images for more details.This is causing tremendous confusion amoung our users.Any suggestions?Thanks,Bryan[ATTACH=CONFIG]31041[/ATTACH] [ATTACH=CONFIG]31042[/ATTACH]
measurement.on("measure-end", function(evt) { if (evt.toolName === "location") { var myResult = "TN State Plane Coordinates (XY):<br />"; myResult += Math.round(evt.geometry.x).toString() + ", " + Math.round(evt.geometry.y).toString(); myResult += "<br><br>"; myResult += "Longitude, Latitude:<br />"; myResult += evt.target.locationX.toFixed(6).toString() + ", " + evt.target.locationY.toFixed(6).toString(); registry.byNode(measurement.resultValue.domNode).setAttribute("content", myResult); } });
For coordinate systems other than Web Mercator or geographic CS, this is by design, since there is no better way to do so.Computing geodesic area/length is only possible with Web Mercator or GCS. Under other CSs, it reprojects the corners (xmin, ymin, xmax, ymax) to GCS, and interpolate the mouse position to find the approximate location under GCS in order to make it possible to calculate geodesic area/length. It is simply not possible to reproject the mouse position point while it's moving. After the drawing ends, as you observed, it shows the accurate result.The better way is to write a projection conversion for this specific needs.BTW, your attached image shows 1018feet, instead of 1108.
Thanks for the info.2 quick questions:1) I have looked at the API and don't see an option to turn off the result update while the mouse is moving. Do you have a snippet of code showing how this is done?2) You have helped me with this one in the past from another post. I need to override the results to show State Plane Coordinates with the location tool. I have the following code which worked in the past but now is acting funny. Basically, I see the info flash into the results pane but then the tool collapses back to the normal results. measurement.on("measure-end", function(evt) { if (evt.toolName === "location") { var myResult = "TN State Plane Coordinates (XY):<br />"; myResult += Math.round(evt.geometry.x).toString() + ", " + Math.round(evt.geometry.y).toString(); myResult += "<br><br>"; myResult += "Longitude, Latitude:<br />"; myResult += evt.target.locationX.toFixed(6).toString() + ", " + evt.target.locationY.toFixed(6).toString(); registry.byNode(measurement.resultValue.domNode).setAttribute("content", myResult); } });
Good work!As API designer, we cannot just support those coordinate systems specifically, unless in the future we can move the whole projection engine to JavaScript in order to support thousands of different coordinate systems. That was why I suggested to write a specific projection converter for this task.Jeff, maybe you would like to share your code.
dojo.provide("org.mymanatee.common.latlong"); dojo.require("dojo.string"); org.mymanatee.common.latlong.convertSPtoLL_LLC = function (uX,uY) { var a = 20925604.48; //major radius of ellipsoid, map units (NAD 83) var ec = 0.08181905782; //eccentricity of ellipsoid (NAD 83) var angRad = 0.01745329252; //number of radians in a degree var pi4 = Math.PI / 4; //Pi / 4 var p0 = 24.333333 * angRad; //latitude of origin var p1 = 24.333333 * angRad; //latitude of first standard parallel var p2 = 31.5 * angRad; //latitude of second standard parallel var m0 = -82.000000 * angRad; //central meridian var x0 = 656166.666667; //False easting of central meridian, map units // Calculate the coordinate system constants. with (Math) { var m1 = cos(p1) / sqrt(1 - (pow(ec,2)) * pow(sin(p1),2)); var m2 = cos(p2) / sqrt(1 - (pow(ec,2)) * pow(sin(p2),2)); var t0 = tan(pi4 - (p0 / 2)); var t1 = tan(pi4 - (p1 / 2)); var t2 = tan(pi4 - (p2 / 2)); t0 = t0 / pow(((1 - (ec * (sin(p0)))) / (1 + (ec * (sin(p0))))),ec/2); t1 = t1 / pow(((1 - (ec * (sin(p1)))) / (1 + (ec * (sin(p1))))),ec/2); t2 = t2 / pow(((1 - (ec * (sin(p2)))) / (1 + (ec * (sin(p2))))),ec/2); var n = log(m1 / m2) / log(t1 / t2); var f = m1 / (n * pow(t1,n)); var rho0 = a * f * pow(t0,n); // Convert the coordinate to Latitude/Longitude. // Calculate the Longitude. var uX = uX - x0; var pi2 = pi4 * 2; var rho = sqrt(pow(uX,2) + pow((rho0 - uY),2)); var theta = atan(uX / (rho0 - uY)); var txy = pow((rho / (a * f)),(1 / n)); var lon = (theta / n) + m0; var uX = uX + x0; // Estimate the Latitude var lat0 = pi2 - (2 * atan(txy)); // Substitute the estimate into the iterative calculation that // converges on the correct Latitude value. var part1 = (1 - (ec * sin(lat0))) / (1 + (ec * sin(lat0))); var lat1 = pi2 - (2 * atan(txy * pow(part1,(ec/2)))); while ((abs(lat1 - lat0)) > 0.000000002) { lat0 = lat1; part1 = (1 - (ec * sin(lat0))) / (1 + (ec * sin(lat0))); lat1 = pi2 - (2 * atan(txy * pow(part1,(ec/2)))); } // Convert from radians to degrees. var Lat = lat1 / angRad; var Lon = lon / angRad; //alert(Lat); //alert(Lon); //Round the latitude and longitude //lat = (CLng(lat * 100000)) / 100000; //lon = (CLng(lon * 100000)) / 100000; Lat = Lat.toPrecision(7); Lon = Lon.toPrecision(8); return [Lat,Lon]; } }; //End of Code for converting map units to decimal degrees. //COnversion to LL from State Plane for Florida West (Transverse mercator, not Lamberic org.mymanatee.common.latlong.convertSPtoLL_TM = function (uX,uY) { var metconv = 1200/3937; //exact survey feet to meters var uXm = uX*metconv; var uYm = uY*metconv; var a = 6378137.000000000000000000; // semimajor axis from ESRI var b = 6356752.314140356100000000; // semiminor axis from ESRI var e2 = ((a*a)-(b*b))/(a*a);//ellipsoid var p0 = 24.333333; //latitude of origin var m0 = -82.000000; //central meridian in degrees var x0 = 656166.666667; //False easting of central meridian, map units var y0 = 0; //False Northing var k0 = 0.999941; //central scale factor k0 var x0m = x0*metconv; var y0m = y0*metconv; var p0rad = p0*Math.PI/180; var m0rad = m0*Math.PI/180; var e = Math.sqrt(e2); var b = a * Math.sqrt(1-e2); var n = (a - b)/(a + b); var G = a*(1-n)*(1-(n*n))*(1+2.25*(n*n)+225/64*(n*n*n*n))*Math.PI/180; var A0 = 1-e2/4-3*(e2*e2)/64-5*(e2*e2*e2)/256; var A2 = 3/8*(e2+(e2*e2)/4+15*(e2*e2*e2)/128); var A4 = 15/256*((e2*e2)+0.75*(e2*e2*e2)); var A6 = 35*(e2*e2*e2)/3072; var lat0 = p0rad; var m0atlat0 = a*(A0*lat0-A2*Math.sin(2*lat0)+A4*Math.sin(4*lat0)-A6*Math.sin(6*lat0)) var NminusNo = uYm - y0m; var m = m0atlat0+NminusNo/k0; var s = (m/G)*Math.PI/180; var fpl1 = (1.5*n-27*(n*n*n)/32)*Math.sin(2*s); var fpl2 = (21*(n*n)/16-55*(n*n*n*n)/32)*Math.sin(4*s); var fpl3 = 151*(n*n*n)/96*Math.sin(6*s); var fpl4 = 1097*(n*n*n*n)/512*Math.sin(8*s); var footptlat = (s+fpl1+fpl2+fpl3+fpl4); var rho = a*(1-e2)/Math.pow((1-e2*Math.sin(footptlat)*Math.sin(footptlat)),1.5); var nu = a/(Math.sqrt(1-e2*Math.sin(footptlat)*Math.sin(footptlat))); var psi = nu/rho; var t = Math.tan(footptlat); var E = uXm-x0m; var x = E/k0/nu; var lat1 = x*E/2; var lat2 = (x*x*x)*E/24*(-4*psi*psi+9*psi*(1-t*t)+12*t*t); var lat3 = (x*x*x*x*x)*E/720*(8*(psi*psi*psi*psi)*(11-24*(t*t))-12*(psi*psi*psi)*(21-71*(t*t))+15*(psi*psi)*(15-98*(t*t)+15*(t*t*t*t))+180*psi*(5*(t*t)-3*(t*t*t*t))+360*(t*t*t*t)); var lat4 = (x*x*x*x*x*x*x)*E/40320*(1385+3633*(t*t)+4095*(t*t*t*t)+1575*(t*t*t*t*t*t)); var lat = footptlat-(t/k0/rho)*(lat1-lat2+lat3-lat4); var latdd = lat*180/Math.PI; var w1 = x/Math.cos(footptlat); var w2 = Math.pow(-1*x,3)/6*(psi+2*t*t)/Math.cos(footptlat); var w3 = Math.pow(x,5)/120/Math.cos(footptlat)*(-4*(psi*psi*psi)*(1-6*(t*t))+(psi*psi)*(9-68*(t*t))+72*(psi)*(t*t)+24*(t*t*t*t)); var w4 = Math.pow(-1*x,7)/5040/Math.cos(footptlat)*(61+662*(t*t)+1320*(t*t*t*t)+720*(t*t*t*t*t*t)); var w = w1+w2+w3+w4; var lon = (-1*m0)*Math.PI/180-w; var londd = (-1*lon)*180/Math.PI; // alert(londd); return [latdd,londd]; }; org.mymanatee.common.latlong.convertLLtoSP_TM = function (lat,lon) { var metconv = 1200/3937; //exact survey feet to meters var a = 6378137.000000000000000000; // semimajor axis from ESRI var b = 6356752.314140356100000000; // semiminor axis from ESRI var e2 = ((a*a)-(b*b))/(a*a);//ellipsoid var p0 = 24.333333; //latitude of origin var m0 = -82.000000; //central meridian in degrees var x0 = 656166.666667; //False easting of central meridian, map units var y0 = 0; //False Northing var k0 = 0.999941; //central scale factor k0 var e = Math.sqrt(e2); var lat0rad_lat0=p0*Math.PI/180; var latrad_lat=lat*Math.PI/180; var rho_lat=a*(1-e2)/Math.pow((1-e2*Math.sin(latrad_lat)*Math.sin(latrad_lat)),1.5); var nu_lat=a/(Math.sqrt(1-e2*Math.sin(latrad_lat)*Math.sin(latrad_lat))); var omega_lat=((lon)*Math.PI/180)-((m0)*Math.PI/180); //provide negative lon so no negative multiplier var psi_lat=nu_lat/rho_lat; var t_lat=Math.tan(latrad_lat); var a0_lat=1-e2/4-3*e2*e2/64-5*e2*e2*e2/256; var a2_lat=3/8*(e2+e2*e2/4+15*e2*e2*e2/128); var a4_lat=15/256*(e2*e2+0.75*e2*e2*e2); var a6_lat=35*e2*e2*e2/3072; var mlat_lat=a*(a0_lat*latrad_lat-a2_lat*Math.sin(2*latrad_lat)+a4_lat*Math.sin(4*latrad_lat)-a6_lat*Math.sin(6*latrad_lat)); var mlat_lat0=a*(a0_lat*lat0rad_lat0-a2_lat*Math.sin(2*lat0rad_lat0)+a4_lat*Math.sin(4*lat0rad_lat0)-a6_lat*Math.sin(6*lat0rad_lat0)); var e1_lat=nu_lat*omega_lat*Math.cos(latrad_lat); var e2_lat=nu_lat*omega_lat*omega_lat*omega_lat/6*Math.cos(latrad_lat)*Math.cos(latrad_lat)*Math.cos(latrad_lat)*(psi_lat-t_lat*t_lat); var e3_lat=nu_lat*Math.pow(omega_lat,5)/120*Math.pow(Math.cos(latrad_lat),5)*(4*psi_lat*psi_lat*psi_lat*(1-6*t_lat*t_lat)+psi_lat*psi_lat*(1+8*t_lat*t_lat)-psi_lat*2*t_lat*t_lat+Math.pow(t_lat,4)); var e4_lat=nu_lat*Math.pow(omega_lat,7)/5040*Math.pow(Math.cos(latrad_lat),7)*(61-479*t_lat*t_lat+179*Math.pow(t_lat,4)-Math.pow(t_lat,6)); var e_lat=k0*(e1_lat+e2_lat+e3_lat+e4_lat); var n1_lat=(omega_lat*omega_lat)/2*Math.cos(latrad_lat); var n1_lat0=n1_lat*nu_lat*Math.sin(latrad_lat); var n2_lat=(Math.pow(omega_lat,4)/24)*(Math.pow(Math.cos(latrad_lat),3))*(4*psi_lat*psi_lat+psi_lat-t_lat*t_lat); var n2_lat0=n2_lat*nu_lat*Math.sin(latrad_lat); var n3_lat=(Math.pow(omega_lat,6)/720)*(Math.pow(Math.cos(latrad_lat),5))*(8*Math.pow(psi_lat,4)*(11-24*t_lat*t_lat)-28*Math.pow(psi_lat,3)*(1-6*t_lat*t_lat)+psi_lat*psi_lat*(1-32*t_lat*t_lat)-2*psi_lat*t_lat*t_lat+Math.pow(t_lat,4)); var n3_lat0=n3_lat*nu_lat*Math.sin(latrad_lat); var n4_lat=(Math.pow(omega_lat,8)/40320)*(Math.pow(Math.cos(latrad_lat),7))*(1385-3111*t_lat*t_lat+543*Math.pow(t_lat,4)-Math.pow(t_lat,6)); var n4_lat0=n4_lat*nu_lat*Math.sin(latrad_lat); var n_lat=k0*(mlat_lat+nu_lat*Math.sin(latrad_lat)*(n1_lat+n2_lat+n3_lat+n4_lat)); var n_lat0=k0*mlat_lat0; var no=n_lat-n_lat0; var x=e_lat+x0*metconv; var y=(n_lat-n_lat0)+y0*metconv; // alert(n_lat); // alert("x="+x+"y="+y); // alert("a0="+a0_lat+"a2="+a2_lat+"a4="+a4_lat+"a6="+a6_lat); var xft=x/metconv; var yft=y/metconv; // alert("x="+xft+"y="+yft); return [xft,yft]; } org.mymanatee.common.latlong.convertWebMercAuxtoLL = function (uX,uY) { //code completely borrowed from http://www.frosties.com/index.php?option=com_mojo&Itemid=45&p=7 // lat and long backwards on link for some reason //alert("IN CONVERSION"); var x = uX; // alert("IN CONVERSION2"); var y = uY; var num3 = x / 6378137.0; var num4 = num3 * 57.295779513082323; //alert("IN CONVERSION3"); var num5 = Math.floor(((num4 + 180.0) / 360.0)); var num6 = num4 - (num5 * 360.0); //alert("IN CONVERSION4"); var num7 = 1.5707963267948966 - (2.0 * Math.atan(Math.exp((-1.0 * y) / 6378137.0))); var lon = num6; var lat = num7*57.295779513082323; // alert([lat,lon]); return [lat,lon]; }; org.mymanatee.common.latlong.convertLLtoWebMercAux = function (lat,lon) { var num = lon * 0.017453292519943295; var x = 6378137.0 * num; var a = lat * 0.017453292519943295; var mercatorX = x; var mercatorY = 3189068.5*Math.log((1.0 + Math.sin(a))/(1.0 - Math.sin(a))); return [mercatorX,mercatorY]; };
The code should still work. Did you require "dijit/registry"?
I had to remove some comments to fit under 10k character capHere is the measurement dijit (too big to post code)www.mymanatee.org/gisapps/mapviewer/js/org/mymanatee/widgets/MeasureWidget.jsand the Coordinate Dijithttp://www.mymanatee.org/gisapps/mapviewer/js/org/mymanatee/widgets/CoordinateWidget.js
