CoffeeScript<\/A>, dus de code is misschien niet het gemakkelijkst te lezen.<\/P><\/P>
Hoe zou je zoiets kunnen bereiken? Laten we een oplossing bekijken.<\/P>
require([\n "dojo\/_base\/_declare",\n "esri\/map",\n "dojo\/_Evented",\n "dojo\/_dom",\n "dojo\/_dom-geometry",\n "dojo\/_dom-attr",\n "dojo\/_on",\n "dojo\/_query",\n "esri\/geometry\/ScreenPoint",\n "esri\/geometry\/screenUtils",\n "esri\/symbols\/PictureMarkerSymbol",\n "esri\/graphic"\n], function(declare, Map, Evented, dom, domGeom, domAttr, on, query, ScreenPoint, screenUtils, PictureMarkerSymbol, Graphic) { \n var cleanup = function(targets) {\n targets.map(function(x) {\n x.remove();\n });\n };\n var DragDropHandler = declare([Evented], {\n dragdrop: function(srcName, targetName) {\n var src = dom.byId(srcName);\n var target = dom.byId(targetName);\n var handlers = [];\n var self = this;\n handlers.push(on(target, 'dragenter', function(e) {e.preventDefault();}));\n handlers.push(on(target, 'dragover', function(e) {e.preventDefault();}));\n handlers.push(on(target, 'dragend', function(e) {cleanup(handlers);}));\n handlers.push(on(src, 'dragstart', function() {\n handlers.push(on(target, 'drop', function(e) {\n e.preventDefault();\n cleanup(handlers);\n var position = domGeom.position(e.currentTarget);\n var x = e.clientX - position.x; \/\/ voor het geval de kaart niet de hele pagina beslaat\n var y = e.clientY - position.y;// voor het geval de kaart niet de hele pagina beslaat\n  .& nbsp.& nbsp.& nbsp.& nbsp.& nbsp.& nbsp.& nbsp.& nbsp.& nbsp.& nbsp.& nbsp.& nbsp.; self.emit('itemdrop', { \n & nbsp.& nbsp.& nbsp.& nbsp.& nbsp.& nbsp.& nbsp.& nbsp;bubbles: true, \n & nbsp.& nbsp.& nbsp.& nbsp.& nbsp.& nbsp.& nbsp.& nbsp;cancelable: true, \n & nbsp.& nbsp.& nbsp.& nbsp.& nbsp.& nbsp.& nbsp.& nbsp;dragsource: src, \n & nbsp.& nbsp.& nbsp.& nbsp.& nbsp.& nbsp.& nbsp.& nbsp;x:x, \n & nbsp.& nbsp.& nbsp.& nbsp.& nbsp.& nbsp.& nbsp.& nbsp;y:y \n & nbsp.; }); \n & nb sp .& nb sp .& nb sp .& nb sp .& nb sp .& nb sp .& nb sp .& nb sp .& nb sp .& nb sp .& nb sp .& nb sp ; }); \n & nb sp .& nb sp ; }); \n & nb sp ; } \n }); \n & nb sp ; var handler = new DragDropHandler(); \n & nb sp ; var map = new Map("mapView", { \n & nb sp .& nb sp ; center: [-118, 34.5], \n & nb sp .& nb sp ; zoom: 8, \n & nb sp .& nb sp ; basemap: "topo" \n }); \n & nb sp ; function addPoint(data) { \n & nb sp .& nb sp ; var mp = screenUtils.toMapGeometry(map.extent, map.width, map.height, data.pt); \n & nb sp .& nb sp ; var pms = new PictureMarkerSymbol(data.url, 24, 24); \n & nb sp .& nb sp ; var graphic = new Graphic(mp, pms); \n & nb sp .& nb sp ; map.graphics.add(graphic); \n } \ n & n b s p ; on(query('.drag-icon'), 'mousedown', function(e) { \ n & n b s p ; v a r s r c N a m e = d o m A t t r g e t ( e c u r r e n t T a r g e t , ' i d ' ) ; \ n & n b s p ; h a n d l e r d r a g d r o p ( s r c N a m e , ' m a p V i e w ' ) ; \ n } ) ; \ n & n b s p ; o n ( h a n d l e r , ' i t e m d r o p ' , f u n c t i o n ( e ) { \ n & n b s p ; v a r d a t a = { \ n & n b s p .& n b s p ; p t : n e w S c r e e n P o i n t ( e . x , e . y ) , \ n & n b s p .& n b s p ; u r l : d o m A t t r g e t ( e . d r a g s o u r c e , ' s r c ' ) \ n & n b s p ; } ; \ n & n b s p ; a d d P o i n t ( d a t a ) ; \ n } ) ; \ n } ) ;<\/PRE><\/P>Dat is eigenlijk niet veel code. De krachtpatser is echt de DragDropHandler<\/STRONG>. Deze DragDropHandler<\/STRONG> heeft een dragdrop<\/EM>-methode die luistert naar sleepgebeurtenissen op een afbeelding en ziet wanneer de afbeelding op de kaart wordt losgelaten. Wanneer deze afbeelding op de kaart wordt losgelaten, hoef je alleen maar een gebeurtenis uit te zenden met schermcoördinaten en wat het gesleepte item was. De ArcGIS JS API biedt enkele hulpmiddelen om schermcoördinaten om te zetten in kaartgeometrieën en voila<\/STRONG><\/EM>, je kunt snel graphics aan de kaart toevoegen en zelfs de afbeeldingsbron kopiëren om deze op de kaart weer te geven!<\/P><\/P>
