We blijven patches aanbieden voor zowel de 10.2.1-nutsbedrijf-release als de 10.6.1-nutsbedrijf-release.<\/P>
After working closely with Esri on this over the past 6 months, we at Schneider Electric are pleased to offer our joint customers another choice as they consider their upgrade plans for #ArcFM and the #UtilityNetwork Management Extension. See the Schneider Electric links below for more information.
http://bit.ly/2nrudKQhttp://bit.ly/2FvAwnu
AED-SICAD has been closely following the further development of ArcGIS beyond the special utility and telecommunication version 10.2.1, ensuring compatibility of the UT for ArcGIS product line with all versions up to the current 10.6. In line with Esri’s recommendations, we have released our desktop product for ArcGIS 10.2.1 and we have only released UT Server for use with the most recent ArcGIS Enterprise versions. When ArcGIS 10.6.1 becomes available this summer, we will release a UT for ArcGIS version of our desktop products that runs on both ArcGIS 10.2.1 and ArcGIS 10.6.1. This will give our customers the option to choose whatever they deem best for their specific IT context.
AED-SICAD will support both 10.2.1 and 10.6.1 until their respective end-of-life dates (June 2021 and January 2024) allowing for a smooth transition to the Utility Network based UT Pro.
More information on:
UT for ArcGIS Pro - AED-SICAD_com
g.hartemaesri-de-esridistk.vondermoselesri-de-esridistgpichler-esristaff
I see they have come out with 10.6.1, but did they ever officially declare it as the Utilities/Telecom version?
I ask as this is about the only reference to it I can find and it is pretty obvious they are not keeping 10.6.1 up to date.
R_
Hi Rhett,
Yes, ArcGIS Desktop 10.6.1 is the next Utility Release. We are in the process of gathering potential utility specific issues for a patch to 10.6.1, but the list of issues is currently relatively small. There are also general patches to 10.6.1 that have come out.
Are you looking for a fix for a specific issue?
thanks, larry
well, yes, mainly this one:
"#BUG-000123209 The Export To CAD tool fails to write BLOCK definitions to output AutoCAD DWG, attribute tags are not created for blocks that are populated, and symbology is not applied."
Tried to escalate, but was informed that since it has been fixed in 10.7.1, that it is not being considered for 10.6.1.
It is almost as if the tech support department isn't even aware the Utilities Telecom version (ran into this with 10.2.1 also).
I have entire development team relying on the CAD exports.
Sad that I have to keep my old 10.2.1 server up and running just to do my ESRI to CAD exports. Everything else on the network has been updated to 10.6.1.
However, out IT department isn't likely to let me keep that old, obsolete server on the net indefinitely.
links no longer work.
That is actually one of the issues we do have on the list to put out as a 10.6.1 UTUP patch. We are in the middle of finishing up a bounce back patch for 10.2.1 as well as the ArcGIS Pro 2.5 and Enterprise 10.8 releases, though, so a little backup at the moment. Hoping to get the 10.6.1 patch out by the end of the year.
Sorry to keep you waiting on this. Have you talked to your account rep about putting in a hot fix request for you?
Hi Larry (and Bill)
I might add that for my part i would appreciate a more "formal" announcement of the Utility Release than in a blog (though i enjoy reading your blog). This information might exist somewhere - but where?
It would be useful for our implementations planning - and as a source for news about bugs, release plans, changes in system requirements etc.
Best regards
Niels
Larry,
I looked into the hot fix a while back, but don't remember why we didn't get it, but was a no go.
Interesting that you are finishing the 10.2.1 patch as I noticed some differences when we went from 10.2.1 to 10.6.1 and was told they couldn't assist me with the 10.2.1 issues anymore as it has been discontinued.
Anyway, hopefully the 10.6.1 patch will be ready by EOY and will no longer be an issue.
Thanks for the info,
