In some of the .Net applications I build, I use the lineSystem.Windows.Forms.Cursor.Current = Windows.Forms.Cursors.WaitCursorat the beginning of a long operation and at the end of the operation, setting it to the default with the line System.Windows.Forms.Cursor.Current = Windows.Forms.Cursors.Default
ICommand pCommand = new ControlsMapZoomInToolClass(); pCommand.OnCreate(map.Object); map.CurrentTool = pCommand as ITool;
using System; using ESRI.ArcGIS.Carto; using ESRI.ArcGIS.Geometry; using ESRI.ArcGIS.Controls; using ESRI.ArcGIS.Display; using ESRI.ArcGIS.SystemUI; using ESRI.ArcGIS.ADF.CATIDs; using System.Runtime.InteropServices; namespace PanZoom { [ClassInterface(ClassInterfaceType.None)] [Guid("2C214724-BFA2-4e8c-BC5D-775C67FA6F51")] public class ZoomIn : ICommand, ITool { #region COM Registration Function(s) [ComRegisterFunction()] [ComVisible(false)] static void RegisterFunction(Type registerType) { // Required for ArcGIS Component Category Registrar support ArcGISCategoryRegistration(registerType); // // TODO: Add any COM registration code here // } [ComUnregisterFunction()] [ComVisible(false)] static void UnregisterFunction(Type registerType) { // Required for ArcGIS Component Category Registrar support ArcGISCategoryUnregistration(registerType); // // TODO: Add any COM unregistration code here // } #region ArcGIS Component Category Registrar generated code /// <summary> /// Required method for ArcGIS Component Category registration - /// Do not modify the contents of this method with the code editor. /// </summary> private static void ArcGISCategoryRegistration(Type registerType) { string regKey = string.Format("HKEY_CLASSES_ROOT\\CLSID\\{{{0}}}", registerType.GUID); ControlsCommands.Register(regKey); } /// <summary> /// Required method for ArcGIS Component Category unregistration - /// Do not modify the contents of this method with the code editor. /// </summary> private static void ArcGISCategoryUnregistration(Type registerType) { string regKey = string.Format("HKEY_CLASSES_ROOT\\CLSID\\{{{0}}}", registerType.GUID); ControlsCommands.Unregister(regKey); } #endregion #endregion [DllImport("gdi32.dll")] static extern bool DeleteObject(IntPtr hObject); private System.Drawing.Bitmap m_bitmap; private IntPtr m_hBitmap; private IHookHelper m_pHookHelper; private INewEnvelopeFeedback m_feedBack; private IPoint m_point; private Boolean m_isMouseDown; private System.Windows.Forms.Cursor m_zoomInCur; private System.Windows.Forms.Cursor m_moveZoomInCur; public ZoomIn() { //Load resources string[] res = GetType().Assembly.GetManifestResourceNames(); if(res.GetLength(0) > 0) { m_bitmap = new System.Drawing.Bitmap(GetType().Assembly.GetManifestResourceStream(GetType(), "ZoomIn.bmp")); if(m_bitmap != null) { m_bitmap.MakeTransparent(m_bitmap.GetPixel(1,1)); m_hBitmap = m_bitmap.GetHbitmap(); } } m_pHookHelper = new HookHelperClass (); } ~ZoomIn() { if(m_hBitmap.ToInt32() != 0) DeleteObject(m_hBitmap); } #region ICommand Members public void OnClick() { } public string Message { get { return "zooms the Display In By Rectangle or Single Click"; } } public int Bitmap { get { return m_hBitmap.ToInt32(); } } public void OnCreate(object hook) { m_pHookHelper.Hook = hook; m_zoomInCur = new System.Windows.Forms.Cursor(GetType().Assembly.GetManifestResourceStream(GetType(), "ZoomIn.cur")); m_moveZoomInCur = new System.Windows.Forms.Cursor(GetType().Assembly.GetManifestResourceStream(GetType(), "MoveZoomIn.cur")); } public string Caption { get { return "Zoom In"; } } public string Tooltip { get { return "Zoom In"; } } public int HelpContextID { get { // TODO: Add ZoomIn.HelpContextID getter implementation return 0; } } public string Name { get { return "Sample_Pan/Zoom_Zoom In"; } } public bool Checked { get { return false; } } public bool Enabled { get { if(m_pHookHelper.FocusMap == null) return false; return true; } } public string HelpFile { get { // TODO: Add ZoomIn.HelpFile getter implementation return null; } } public string Category { get { return "Sample_Pan/Zoom"; } } #endregion #region ITool Members public void OnMouseDown(int button, int shift, int x, int y) { if(m_pHookHelper.ActiveView == null) return; //If the active view is a page layout if(m_pHookHelper.ActiveView is IPageLayout) { //Create a point in map coordinates IPoint pPoint = (IPoint) m_pHookHelper.ActiveView.ScreenDisplay.DisplayTransformation.ToMapPoint(x, y); //Get the map if the point is within a data frame IMap pMap = m_pHookHelper.ActiveView.HitTestMap(pPoint); if(pMap == null) return; //Set the map to be the page layout's focus map if(pMap != m_pHookHelper.FocusMap) { m_pHookHelper.ActiveView.FocusMap = pMap; m_pHookHelper.ActiveView.PartialRefresh(esriViewDrawPhase.esriViewGraphics, null, null); } } //Create a point in map coordinates IActiveView pActiveView = (IActiveView) m_pHookHelper.FocusMap; m_point = pActiveView.ScreenDisplay.DisplayTransformation.ToMapPoint(x, y); m_isMouseDown = true; } public void OnMouseMove(int button, int shift, int x, int y) { if(!m_isMouseDown) return; //Get the focus map IActiveView pActiveView = (IActiveView) m_pHookHelper.FocusMap; //Start an envelope feedback if(m_feedBack == null) { m_feedBack = new NewEnvelopeFeedbackClass(); m_feedBack.Display = pActiveView.ScreenDisplay; m_feedBack.Start(m_point); } //Move the envelope feedback m_feedBack.MoveTo(pActiveView.ScreenDisplay.DisplayTransformation.ToMapPoint(x, y)); } public void OnMouseUp(int button, int shift, int x, int y) { if(!m_isMouseDown) return; //Get the focus map IActiveView pActiveView = (IActiveView) m_pHookHelper.FocusMap; //If an envelope has not been tracked IEnvelope pEnvelope; if(m_feedBack == null) { //Zoom in from mouse click pEnvelope = pActiveView.Extent; pEnvelope.Expand(0.5, 0.5, true); pEnvelope.CenterAt(m_point); } else { //Stop the envelope feedback pEnvelope = m_feedBack.Stop(); //Exit if the envelope height or width is 0 if(pEnvelope.Width ==0 || pEnvelope.Height == 0) { m_feedBack = null; m_isMouseDown = false; } } //Set the new extent pActiveView.Extent = pEnvelope; //Refresh the active view pActiveView.Refresh(); m_feedBack = null; m_isMouseDown = false; } public void OnKeyDown(int keyCode, int shift) { if(m_isMouseDown) { if(keyCode == 27) { m_isMouseDown = false; m_feedBack = null; m_pHookHelper.ActiveView.PartialRefresh(esriViewDrawPhase.esriViewForeground, null, null); } } } public void OnKeyUp(int keyCode, int shift) { // TODO: Add ZoomIn.OnKeyUp implementation } public int Cursor { get { if(m_isMouseDown) return m_moveZoomInCur.Handle.ToInt32(); else return m_zoomInCur.Handle.ToInt32(); } } public bool OnContextMenu(int x, int y) { // TODO: Add ZoomIn.OnContextMenu implementation return false; } public bool Deactivate() { return true; } public void Refresh(int hdc) { // TODO: Add ZoomIn.Refresh implementation } public void OnDblClick() { // TODO: Add ZoomIn.OnDblClick implementation } #endregion } }
You can create custom zoomin tool that inherits from itool and customize the cursor. Replace ControlsMapZoomInToolClass with custom zoom in tool.
not that I know of
So it is really not "change the cursor of an ITool" but create a new tool with a cursor.
(If you have to re-write the tool then that kind defeats the purpose of even having those tools available for use.)
It�??s not like I�??m imposing any one here to use the solution. If you don�??t like it don�??t implement it.
Thank you for your reply, I already thought that solution, but ZoomIn is not the only tool I am using, and I don't want to replace all the tools I am using just because I want to change the icon. I cannot understand why the Cursor property is read only...
