Does anybody experience the problem with SDK download? It completely installs and at the end it says "rolling back action".
Please let me know.
Thank you
Regards,
Siva P Vysyaraju
Could you try to install the SDK by running and send me the log file?
msiexec /i C:\Temp\netsdk\SetupFiles\Setup.msi /l*v c:\DotNET_SDK_Install_LOG.log
Hi, I got it fixed. all i need to do is, un-check the visual studio 2012 setup
Antti Kajanus 撰写:Could you try to install the SDK by running and send me the log file?msiexec /i C:\Temp\netsdk\SetupFiles\Setup.msi /l*v c:\DotNET_SDK_Install_LOG.log
Antti Kajanus 撰写:
I've got the same problem and followed your method.
A really huge log file was generated. Could you please help me find out something meaningful in it?
https://www.dropbox.com/s/myk3zpryncsos02/DotNET_SDK_Install_LOG.zip?dl=0
I'm not sure whether or not to "un-check the visual studio 2012 setup" (I'm using VS2013) is appropriate. The installation complete, it works, but without templete integrated into VS, is there anything I need to do manually?
Thanks for providing a log. There shouldn't be anything that you need to do manually.
Can you check if the templates are laid to the disc? For example, you can find desktop from template from C:\Program Files (x86)\Microsoft Visual Studio 12.0\Common7\IDE\ProjectTemplates\CSharp\Windows\1033\
If the templates are there, you could try to run either /installVStemplates or /setup command from command line.
Thank you for your reply.
I have checked the folder named "2052"(the folder named "1033" does not exist) and found nothing. But I've got something else:
In this folder "C:\Program Files (x86)\Microsoft Visual Studio 12.0\Common7\IDE\ProjectTemplatesCache\CSharp\Windows\1033\ArcGISRuntime.Desktop.10.2.4.zip(the folder name, not a zip file)",these files are laid:
I have finished the first step in Tutorials——“Add a map to your app” successfully. It seems that everything is OK, to add the reference, to start debugging……
Maybe I just doesn't need to worry about it?
I created the folder "1033" manually, executed the setup.exe again, selected the maintenance operation "Modify", checked both "Blend for Visual Studio 2013" and "Visual Studio 2013", then the installation finished successfully.
A new file named "ArcGISRuntime.Desktop.10.2.4.zip"(a zip file not a folder) was laid in both
"C:\Program Files (x86)\Microsoft Visual Studio 12.0\Blend\ProjectTemplates\en\CSharp\Wpf"
and
"C:\Program Files (x86)\Microsoft Visual Studio 12.0\Common7\IDE\ProjectTemplates\CSharp\Windows\1033".
Nothing else different.No new items in "New Project" window of VS2013.
Uh……
