"De snelle en gemakkelijke toegang tot gegevens die Survey123 biedt, helpt Iowa DOT om de meest kosteneffectieve manier te bepalen om het wegdek te repareren en tegelijkertijd de wegen veiliger te maken."<\/SPAN><\/SPAN><\/P><\/SPAN><\/P>Het Office of Construction and Materials van Iowa DOT doet geweldig werk met Esri's <\/SPAN><\/SPAN><\/SPAN><\/A>"Survey123 for ArcGIS"-software. Lees meer HIER<\/A>.<\/SPAN><\/SPAN><\/P><\/BODY><\/HTML>
Motivated and visionary people in the construction office at Iowa DOT. Having an ESRI technology framework, minimal bureaucratic process, good people along with an enterprise training plan allows staff to create and be GISuccessful at Iowa DOT. Thanks for posting.
Eric, this is a great example of how Survey123 can be used at a DOT. Is there any chance you could post the Survey 123 form to the Departments of Transportation group? My guess is that other DOTs have a similar form so starting from your form would save time.
Link to template
http://iowadot.maps.arcgis.com/home/item.html?id=471371f9060b42bf82752fe1a01d7af7
Direct download
https://iowadot.maps.arcgis.com/sharing/rest/content/items/471371f9060b42bf82752fe1a01d7af7/data
Thanks Eric! This is great. I’ll try it out.
My pleasure, Eric. Happy to work with you all on this!
