How do you remove FeatureClass from file geodatabase programmatically using the ArcGIS Pro SDK?
Thank´s
DDL (data definition language) operations are not natively supported in the Pro SDK. You need to use the geoprocessing routines to run the "Delete" tool to delete the dataset.
I hope this helps,
--Rich
Hi Wolf,
How do you remove WMTS layer using the ArcGIS Pro SDK?
Hi Wolfgang,
Thank you.It's working perfectly.
There is a sample that deletes a table from a File Geodatabase: Edit Operation Row Event
You might be able to use this snippet from this sample:
QueuedTask<SPAN class="punctuation token">.</SPAN><SPAN class="token function">Run</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">async</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="operator token">=</SPAN><SPAN class="operator token">></SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="comment token">//find layer and derive geodatabase</SPAN> <SPAN class="keyword token">var</SPAN> cpLayer <SPAN class="operator token">=</SPAN> MapView<SPAN class="punctuation token">.</SPAN>Active<SPAN class="punctuation token">.</SPAN>Map<SPAN class="punctuation token">.</SPAN><SPAN class="token function">FindLayers</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"CrowdPlanning"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">FirstOrDefault</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">as</SPAN> FeatureLayer<SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">var</SPAN> geodatabase <SPAN class="operator token">=</SPAN> cpLayer<SPAN class="punctuation token">.</SPAN><SPAN class="token function">GetFeatureClass</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">GetDatastore</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">as</SPAN> Geodatabase<SPAN class="punctuation token">;</SPAN> <SPAN class="comment token">//Advise </SPAN> <SPAN class="comment token">//Delete the editlog table</SPAN> <SPAN class="keyword token">var</SPAN> mva <SPAN class="operator token">=</SPAN> Geoprocessing<SPAN class="punctuation token">.</SPAN><SPAN class="token function">MakeValueArray</SPAN><SPAN class="punctuation token">(</SPAN>geodatabase<SPAN class="punctuation token">.</SPAN><SPAN class="token function">GetPath</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN>AbsolutePath<SPAN class="punctuation token">,</SPAN><SPAN class="string token">"EditLog"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">await</SPAN> Geoprocessing<SPAN class="punctuation token">.</SPAN><SPAN class="token function">ExecuteToolAsync</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"Delete_management"</SPAN><SPAN class="punctuation token">,</SPAN> mva<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
Hi Rich,
Thank you for answering my question.
I'll give "Delete" tool a try.
