When using favorite answers, i noticed that it can copy in the old location. This is problematic as it can result in multiple records with the same geometry. If the GPS has acquired a lock before pasting in the favorite answers then it doesn't copy in your old location. However, if the GPS is still trying to find a lock as you paste in your favorite answers then it enters in the old location. Is there anyway to avoid this issue? Usually pasting in your favorite answers is the first step folks take which if the device hasn't acquired a signal will be bad.
