I have a feature class of points and want to retrieve information about the polygon that a particular point falls within using SQL. The following query works however it does not return any results:
select * from Basins
join (Select Shape from Pointlayer where Increment = 02047) as Point
on Basins.Shape.STWithin(Point.Shape) = 1;
I have also tried STIntersects with the same result.
Next I created a feature class that contained a single point and the query did return the correct result. It seems to be failing at evaluation the Select statement for the join. When run by itself the select statement does return the Shape field however when embedded in the join query it fails.
Any help would be appreciated.
