I have different Spatial Dataframes which I want to combine in one Feature Service. As the Dataframes have different geometry types and attributes I need one Feature Service with different Layers. First I created an empty Feature Service and tried to update the layer's section of the service definition. The following workflow did not work and there was no change in the service definition.
newService <SPAN class="operator token">=</SPAN> gis<SPAN class="punctuation token">.</SPAN>content<SPAN class="punctuation token">.</SPAN>create_service<SPAN class="punctuation token">(</SPAN><SPAN class="string token">"CombineLayers_New"</SPAN><SPAN class="punctuation token">,</SPAN> service_type<SPAN class="operator token">=</SPAN><SPAN class="string token">'featureService'</SPAN><SPAN class="punctuation token">)</SPAN>
newFeatureLayerCollection <SPAN class="operator token">=</SPAN> features<SPAN class="punctuation token">.</SPAN>FeatureLayerCollection<SPAN class="punctuation token">.</SPAN>fromitem<SPAN class="punctuation token">(</SPAN>newService<SPAN class="punctuation token">)</SPAN>
dictLayer <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">{</SPAN><SPAN class="punctuation token">}</SPAN>
dictLayer<SPAN class="punctuation token">[</SPAN><SPAN class="string token">"geometryType"</SPAN><SPAN class="punctuation token">]</SPAN> <SPAN class="operator token">=</SPAN> <SPAN class="string token">"esriGeometryPoint"</SPAN>
dictLayer<SPAN class="punctuation token">[</SPAN><SPAN class="string token">"name"</SPAN><SPAN class="punctuation token">]</SPAN> <SPAN class="operator token">=</SPAN> <SPAN class="string token">"AuGeoPoints"</SPAN>
dictLayer<SPAN class="punctuation token">[</SPAN><SPAN class="string token">"id"</SPAN><SPAN class="punctuation token">]</SPAN> <SPAN class="operator token">=</SPAN> <SPAN class="number token">0</SPAN>
layersList <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="punctuation token">]</SPAN>
layersList<SPAN class="punctuation token">.</SPAN>append<SPAN class="punctuation token">(</SPAN>dictLayer<SPAN class="punctuation token">)</SPAN>
dictUpdate <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">{</SPAN><SPAN class="string token">"layers"</SPAN> <SPAN class="punctuation token">:</SPAN> layersList <SPAN class="punctuation token">}</SPAN>
newFeatureLayerCollection<SPAN class="punctuation token">.</SPAN>manager<SPAN class="punctuation token">.</SPAN>update_definition<SPAN class="punctuation token">(</SPAN>dictUpdate<SPAN class="punctuation token">)</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>How can I publish a Feature Service and add more than one Feature Layer?
rsingh-esristaff
