Just wondering if the Survey 123 Web Designer and Survey 123 Connect Application are fully compatible - that is, that surveys created in Connect Application can be edited in Web Designer (and the reverse).
Hi Leandra,
You can start authoring surveys in Survey123 Web Designer, publish them - then bring them into Survey123 Connect to edit/modify the survey, then re-publish the survey. The reverse workflow (e.g., from Survey123 Connect to Web Designer) is not supported.
Hope this helps,
Thanks Derek, I figured that might be the case. Just wanted to double check before I started developing forms!
Hi DerekLaw,
Any chance that the reverse workflow (e.g. from Survey123 Connect to Web Designer) is supported now? I want to edit transferred content in Survey123 web designer, or at least copy the original survey for edit capabilities online.
