I am trying to find out why the python script that I wrote isnt working. I am trying to count the number of stairs in a stairwell. I have two shapefiles and i wrote the script to run auto and process how many stairs there are. if someone can help me with this I would appreciate it thanks.
Sharing with Python since this looks to be ArcPy and not ArcGIS API for Python.
Please paste the code (not a screenshot) and use /blogs/dan_patterson/2016/08/14/script-formatting?sr=search&searchId=bdf45239-640f-4c59-b3e5-bbc4c8db4364&searchIndex=0. Also, provide the error and traceback if you are getting an error. If you are seeing unexpected results, describe what you are seeing and what you expect.
here is the code below. again im not too familar with python so i am asking for some help
def createInternalParallelLines(): # import libraries import arcpy
# set input/output parameters polyFC = arcpy.GetParameterAsText(0) # input polygons outParallel = arcpy.GetParameterAsText(1) # output parallel lines lineSpacing = arcpy.GetParameterAsText(2) # line spacing buffDist = arcpy.GetParameterAsText(3) # inner buffer distance
# parse numbers from parameters lineSpaceNum = float(lineSpacing.split(' ')[0]) buffNum = float(buffDist.split(' ')[0])
# establish spatial reference desc = arcpy.Describe(polyFC) SR = desc.spatialReference
# set overwrite environment arcpy.env.overwriteOutput = True arcpy.env.outputCoordinateSystem = SR
parallels = [] # create hull rectangle to establish a rotated area of interest coordSplit = row[0].hullRectangle.split(' ')
# collect corner coordinates coordList = arcpy.Array([arcpy.Point(coordSplit[0],coordSplit[1]),arcpy.Point(coordSplit[2],coordSplit[3]),arcpy.Point(coordSplit[4],coordSplit[5]),arcpy.Point(coordSplit[6],coordSplit[7]),arcpy.Point(coordSplit[0],coordSplit[1])])
# create lines from hull rectangle currentLines = [] for pointNum in range(0,4): arcpy.Array([coordList.getObject(pointNum),coordList.getObject(pointNum+1)]) hullRecLine = arcpy.Polyline(arcpy.A # loop through each input shape for row in arcpy.da.SearchCursor(polyFC, ["SHAPE@"], spatial_reference=SR):
# create inner buffer polyBuff = row[0].buffer(buffNum * -1)rray([coordList.getObject(pointNum),coordList.getObject(pointNum+1)])) currentLines.append(hullRecLine)
# compare first and second line to determine if first line is short or long firstLong = 0 if currentLines[0].length < currentLines[1].length: firstLong = 1
# calculate number of points needed along short axis numPoints = int(math.floor(currentLines[firstLong].length/lineSpaceNum))
# create and join points to create parallel lines for point in range(1,numPoints+1): shortPoint1 = currentLines[firstLong].positionAlongLine(lineSpaceNum*point) shortPoint2 = currentLines[firstLong + 2].positionAlongLine(currentLines[firstLong + 2].length - (lineSpaceNum*point)) parallel = arcpy.Polyline(arcpy.Array([shortPoint1.centroid,shortPoint2.centroid]), SR)
# intersect parallel lines with buffer parallelBuff = parallel.intersect(polyBuff,2) parallels.append(parallelBuff)
# write geometries to disk arcpy.CopyFeatures_management(parallels, outParallel)
# add to map mxd = arcpy.mapping.MapDocument("CURRENT") dataFrame = arcpy.mapping.ListDataFrames(mxd, "*")[0] addLayer = arcpy.mapping.Layer(outParallel) arcpy.mapping.AddLayer(dataFrame, addLayer)
del row
Here is the code… thanks for your help
import libraries
import arcpy
parallels = []
currentLines = []
arcpy.Array()
create inner buffer
rray())
firstLong = 0
firstLong = 1
parallel = arcpy.Polyline(arcpy.Array(), SR)
add to map
Follow your other post
https://community.esri.com/thread/222977-arcpy-scripting-error-question
and use the code formatting link in there.
There are other unaddressed questions as well.
