wanneer ik de arcgis hec-geohms tool verwerkingsprocedure gebruik, is het probleem opgetreden bij stroomsegmentatie. <\/P><\/BODY><\/HTML>
try saving the file to a simpler folder ie c:\test
many times it is either the source and/or destination file name that isn't appreciated by the software.
it doesn't work. same error shows up.
ERROR 010419: Unable to build the attribute table of C:\test\Layers\Fdr as required by the operation.
Failed to execute (StreamLink)
this problem bothers me a lot and i can't go on my project cause of this. can you just help me find out the solution. i really appreciate.
thank you
i try to create attribute table for Fdr(flow direction) , but in the usage they said that :
It is not possible to build a raster attribute table for a raster dataset that is a pixel type of 32-bit floating point。
and i went to check it . my dataset seems to a pixel type of 32-bit floating boat , what should i do?
That is indeed the error, you have to convert it to integer format, it seems that you have obtained floating point values for whatever reason. I would revisit your workflow to ensure that you are using the correct input file.
i download the input file from hec-geohms official website and it is a
example date . the format of DTM(DEM) is (w001001.adf) . i cant add this
data from GIS add data tool . i input the by pool file into GIS .
and how can i convert floating point to integral data?
