The process to select by using Sketch tools is not working in 2.3. I double checked to make sure it was not just my code by downloading a fresh set of the samples from here GitHub - Esri/arcgis-pro-sdk-community-samples: ArcGIS Pro SDK for Microsoft .NET Framework Community Samples and ran of the Feature Selection and the Map Tool Select without changing a thing and they both fail. Is there a known fix to this?
Correct. Normal out of the box works fine. My custom code and the ESRI samples code downloaded from GitHub fails. Worked fine in 2.2.
When you use the Pro sketch tools (Map Tab on the ribbon) to select on your sde database features, does that work? Is it only the custom sketch tools in samples and add-ins that are exhibiting this behavior?
No exception thrown. It sits and spins for 5-10 minutes, all others tools are grayed out, the refresh spins, and nothing gets selected. All features are in a sde database.
Hi Matthew
When you use the sketch tools with 2.3, are you seeing an exception thrown by the code or that nothing gets selected on the map?
Uma
